Problem upgrading from 7.1.5 to 7.1.9
After upgrading Pega Academy from 7.1.5 to 7.1.9 the pyCaseManger7 harness in the Data-Portal class is not rendering properly. This harness has a standard screen layout with a header section across the top, a navigation section on the left and a content section on the right. Individually, each section previews correctly. However when trying to display them all together, the header appears on the top, the nav section on the left, then it's as if someone added a bunch of newline/carriage returns and forced the content section to appear way down at the bottom of the page, far from the header or nav sections.
I have confirmed that the harness rule is correct in the portal rule, and that the harness and sections match up correctly with a known good 7.1.5 environment. I have checked all settings on each form to ensure they match with the comparable rules in the 7.1.5 environment. There are messages about updated ways to do things in Pega7, and although these will be updated soon, the harness should display without this large blank space and incorrect section rendering as it does now.
If anyone has seen this or has an idea, please let me know.
