Pega 7.4 Upgrade from 7.1.5 in different regions
Hi
Our application was in 7.1 Split Schema. Lets have the schema name as 71_Rules, 71_Data.
In Dev we upgraded to 7.4 using upgrade scripts to new schemas 74_Rules, 74_Data.
For QA this was what I did.
Moved 74_Rules from Dev to QA. Moved 71_Data from QA to 74_Data QA.
Then ran Upgrade --dataonly, the script fails for many tables to be created.
Whats the smart way to do this? Or running all upgrade scripts in different regions is the only option?
If I run upgrade scripts in different regions, I have to move the upgrade fix as Jar seperately. Pls guide
