How can I put paragraph data into a text property?
I have to create a SOAP Connect using a connector. Integration-Connectors and Integration- Mapping class is done! So i have been coming to the point to fill the request data with values.
I have created a Paragraph Rule which include the whole HTML part as a string (properties are referenced). Within my XML Stream i have got an Element called XML( Property XMLRequest Type Text).
So my question is how can I put the paragraph data into the XMLRequest Property?
Thanks a lot
Screens:
On Clipboard I found following data under pySourceStream
Is it possible to use this Kind of data?
thanks
