Posted: Nov 22, 2015
Last activity: Nov 23, 2015
could you please share the configuration details or try redeploying prsysmgmt.war file...
Hi Brahmeswara,
Can you please share application server used and whether you are accessing SMA on HTTPS?
Hi ,
Can you use Local Java option and try connecting to the node?
No issues after chosen Local JVM Connection - SMA is installed on PRPC Server.
Thanks to everybody .
