![](/themes/custom/pegacc_theme/images/user-icon.png)
Last activity: 5 Apr 2016 21:21 EDT
Does anyone know when this error is logged?(PRRuntime Error: Failed to find a 'RULE-OBJ-ACTIVITY' with the name 'NULL')
We are seeing so many entries in logs "PRRuntime Error: Failed to find a 'RULE-OBJ-ACTIVITY' with the name 'NULL' that applies to 'MyOrg-FW-DIV-Data-ABCInfo'; no rules with this name were found in the rulebase."
Appreciate any help or insight into this issue.
Hi Govardhan,
Which PRPC version you are using?
Do you remember having this class, MyOrg-FW-DIV-Data-ABCInfo, earlier in your application?
Try clearing the PRPC cache tables, restart server and see if you notice this again.
Thanks Arvind for your response. We are using 7.1.7. We still have the class in our app.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2024-08/ef69651d-5c2a-46e8-aee2-6ad474f73db6.png?h=b6be84b4&itok=Cx2phisk)
GovCIO
Hi Govardhan,
I hope you might have checked the below PDN article for your issue stand point. If not, pls have a look at it.Not sure whether the mentioned HF applies to your issue or not.
Ravi Kumar.
Thanks Ravi. I just referred the pdn article you suggested. In our scenario the activity name in the logs say 'NULL'.
may be a poor comment...
- checking the recent deleted activity rules if activity by name NULL is created and deleted at first place for test.
- would doing re-validate & save help?
- or application validation tool
- its run time error though ...
- not just at the place of error, can we look through the caller and calling activity list/chain...
- or running RULE-OBJ-ACTIVITY CODE-PEGA- PYEXTRACTCODE be of use?
Thanks Phani, will try your recommendations. Any input in the process of issue resolution is certainly valuable for us and saves time.
Were you able to address this Issue.
I am seeing a similar issue with one of the clients and any feedback would greatly help.
No Amar. It was a low priority issue for us and never got chance to look at it later on.
Pegasystems
Is it possible the thread was thrown away or cleaned up by the last step of activity RedirectAndRun ? Is it possible some activity is renaming the primary page away to something else ?
if you post a zipped save of a pega trace with all event types and rulesets enabled of this issue occurring (make sure you zip or 7-z it to save space!) , one of us may be able to spot something. /Eric
