    Atos Syntel
Last activity: 29 Dec 2016 1:08 EST
prpcUtils.bat does not continue after step - Will load phase 2 bootstrap from Pega-EngineCode:07-10-15
I am trying to use prpcUtils scripting for the first time, tried exporting a RAP but the script didn't continue after step - "Will load phase 2 bootstrap from Pega-EngineCode:07-10-15"
Found some entries in the execution log where both forward and backward slashes were used in the directories, i think they might be the reason.
------------------------------Below is the execution log-----------------------------------
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\xbbklhx>cd C:\Data\PRPC setups\114716_Pega717\scripts\utils
C:\Data\PRPC setups\114716_Pega717\scripts\utils>prpcUtils.bat exportRAP
Invoke our ant script, passing in the arguments as collected
Buildfile: C:\Data\PRPC setups\114716_Pega717\scripts\utils\prpcUtils.xml
-init:
[pega:propertyparser] Reading Properties from : C:\Data\PRPC setups\114716_Pega7
17\scripts\utils/prpcUtils.properties
[pega:propertyparser] pega.jdbc.driver.jar=C:\Users\xbbklhx\Desktop\Jars\ojdbc6-
Proprietary information hidden.0.jar
[pega:propertyparser] pega.jdbc.driver.class=oracle.jdbc.OracleDriver
[pega:propertyparser] pega.database.type=oracledate
[pega:propertyparser] pega.jdbc.url=jdbc:oracle:thin:@r55cn00.bnymellon.net:4000
3/oopegt01.bnymellon.net
[pega:propertyparser] pega.jdbc.username=PRPC_SB2
[pega:propertyparser] pega.jdbc.password=******
[pega:propertyparser] pega.user.username=xbbklhx
-init:
[pega:propertyparser] pega.user.password=rule105
[pega:propertyparser] rules.schema.name=PRPC_SB2
[pega:propertyparser] data.schema.name=PRPC_SB2
[pega:propertyparser] pega.agents.enable=true
[pega:propertyparser] column.population.job.mode=COMMANDLINE_JOB
[pega:propertyparser] user.temp.dir=C:\Users\xbbklhx\Desktop\Jars\Export\pega_te
mp
[pega:propertyparser] import.archive.path=C:\Users\xbbklhx\Desktop\Jars\Export\i
mportfile.zip
[pega:propertyparser] import.mode=import
[pega:propertyparser] import.existing.instances=skip
[pega:propertyparser] import.nofailonerror=false
[pega:propertyparser] import.commit.count=100
[pega:propertyparser] import.compile.libraries=true
[pega:propertyparser] import.codeset.name=Customer
[pega:propertyparser] import.codeset.version=06-01-01
[pega:propertyparser] export.archive.full.path=C:\Users\xbbklhx\Desktop\Jars\Exp
ort\exported-Jan-5.zip
[pega:propertyparser] export.archive.productkey=RULE-ADMIN-PRODUCT TEST 01-01-01
#20151215T145331.290 GMT
[pega:propertyparser] export.classes.included=
[pega:propertyparser] export.included.descendent=true
[pega:propertyparser] export.classes.excluded=
[pega:propertyparser] export.excluded.descendent=true
[pega:propertyparser] export.startVersion=
[pega:propertyparser] export.endVersion=
[pega:propertyparser] export.keys.file=
[pega:propertyparser] export.ruleset.name=
[pega:propertyparser] export.application.context=
[pega:propertyparser] export.preserve.locks=false
[pega:propertyparser] export.migration.xml=
[pega:propertyparser] export.migration.date=
[pega:propertyparser] expose.classes.included=
[pega:propertyparser] expose.included.descendent=true
[pega:propertyparser] expose.classes.excluded=
[pega:propertyparser] expose.excluded.descendent=true
[pega:propertyparser] expose.declareIndex.accessgroup=
[pega:propertyparser] expose.startKey=
[pega:propertyparser] expose.endKey=
[pega:propertyparser] expose.startDate=
[pega:propertyparser] expose.endDate=
[pega:propertyparser] expose.reindex=true
[pega:propertyparser] expose.reindexType=nonpega
[pega:propertyparser] expose.commitRate=100
[pega:propertyparser] expose.numOfThreads=
[pega:propertyparser] resave.classes.included=true
[pega:propertyparser] resave.included.descendent=true
[pega:propertyparser] resave.classes.excluded=false
[pega:propertyparser] resave.excluded.descendent=true
[pega:propertyparser] resave.startKey=
[pega:propertyparser] resave.endKey=
[pega:propertyparser] resave.startDate=
[pega:propertyparser] resave.endDate=
[pega:propertyparser] runagent.agentruleset=Pega-RulesEngine
[pega:propertyparser] runagent.agentname=PropertyOptimization
[pega:propertyparser] scan.applicationName=PegaRULES
[pega:propertyparser] scan.applicationVersion=
[pega:propertyparser] scan.lib.external.jars=
[pega:propertyparser] scan.result.file=C:\Users\xbbklhx\Desktop\Jars\Export\Resu
lts.csv
[pega:propertyparser] scan.ruletypes.file=C:\Users\xbbklhx\Desktop\Jars\Export\R
uleTypes.txt
[pega:propertyparser] manage.hotfix=
[pega:propertyparser] syntax.rules.excludeCore=false
[pega:propertyparser] syntax.rules.allVersions=true
[pega:hasenoughspace] Found 9327236KB of free space on 'C:\Users\xbbklhx\AppData
\Local\Temp\'
[mkdir] Created dir: C:\Users\xbbklhx\AppData\Local\Temp\PegaInstallTemp-16-
December-2015-22.14.01\load
December-2015-22.14.01\pr_temp
[echo] Using C:\Users\xbbklhx\AppData\Local\Temp\/PegaInstallTemp-16-Decemb
ER-2015-22.14.01 for install scratch space...
[unzip] Expanding: C:\Data\PRPC setups\114716_Pega717\archives\prweb.war int
o C:\Users\xbbklhx\AppData\Local\Temp\PegaInstallTemp-16-December-2015-22.14.01\
load
[unzip] Expanding: C:\Data\PRPC setups\114716_Pega717\archives\pegadbinstall
-classes.zip into C:\Users\xbbklhx\AppData\Local\Temp\PegaInstallTemp-16-Decembe
[copy] Copying 1 file to C:\Users\xbbklhx\AppData\Local\Temp\PegaInstallTem
p-16-December-2015-22.14.01\load\lib
p-16-December-2015-22.14.01\load\WEB-INF\classes
Checking Configuration Files:
_findSystemName:
[echo] select max(s.pySystemName) from PRPC_SB2.pr_data_admin s inner join
PRPC_SB2.pr_data_admin r on s.pySystemName = r.pySystemName where s.pxobjc
lass = 'Data-Admin-System' and r.pxObjClass = 'Data-Admin-Requestor'
Processing Configuration Files:
[propertyfile] Creating new property file: C:\Users\xbbklhx\AppData\Local\Temp\P
egaInstallTemp-16-December-2015-22.14.01\prbootstrap.properties
Configuration:
[echo] Database Type: oracledate
[echo] JDBC Driver JAR: C:\Users\xbbklhx\Desktop\Jars\ojdbc6- Proprietary information hidden.0.jar
[echo] Bootstrap Config: C:\Users\xbbklhx\AppData\Local\Temp\/PegaInstallTe
mp-16-December-2015-22.14.01/prbootstrap.properties
[echo] PegaRULES Config: C:\Users\xbbklhx\AppData\Local\Temp\/PegaInstallTe
mp-16-December-2015-22.14.01/prconfig.xml
[echo] PegaRULES Logging Config: C:\Users\xbbklhx\AppData\Local\Temp\/PegaI
nstallTemp-16-December-2015-22.14.01/prlogging.xml
-exportRAP:
[echo] about to Export Product 'RULE-ADMIN-PRODUCT TEST 01-01-01 #20151215T
145331.290 GMT' to : C:\Users\xbbklhx\Desktop\Jars\Export\exported-Jan-5.zip arc
hive ...
[echo] u/p -U xbbklhx -P rule105
[echo] arg line : : -p "RULE-ADMIN-PRODUCT TEST 01-01-01 #20151215T145331.
290 GMT" -o "C:\Users\xbbklhx\Desktop\Jars\Export\exported-Jan-5.zip" -U xbbklhx
-P rule105
[java] Dec 16, 2015 10:14:15 PM com.pega.pegarules.internal.bootstrap.PRBoo
tstrapDataSource
[java] 19830421: Loading bootstrap properties from file:///C:\Users\xbbklhx
\AppData\Local\Temp\/PegaInstallTemp-16-December-2015-22.14.01/prbootstrap.prope
rties
[java] Dec 16, 2015 10:14:15 PM com.pega.pegarules.internal.bootstrap.Setti
ngReaderJNDI
[java] 19830421: Could not find java:comp/env/prbootstrap/ in the local JND
I context, skipping prconfig setting lookup
ngReaderJNDI
[java] 19830421: Could not find prbootstrap in the local JNDI context, skip
tstrapDataSource
[java] 19830421: Bootstrap datatables schema: PRPC_SB2
[java] Dec 16, 2015 10:14:21 PM com.pega.pegarules.internal.bootstrap.PRBoo
tstrap
[java] 19830421: Engine schema defined in allclasses: null
[java] Dec 16, 2015 10:14:21 PM com.pega.pegarules.internal.bootstrap.Setti
ngReaderJNDI
[java] 19830421: Could not find java:comp/env/prconfig/ in the local JNDI c
ngReaderJNDI
[java] 19830421: Could not find prconfig in the local JNDI context, skippin
tstrap
[java] 19830421: Engine classes schema: null
tstrap
[java] 19830421: Assembled classes schema: null
tstrap
[java] 19830421: prbootstrap.properties merged with prbootstrap entries in
Data-Admin-System-Settings
[java] Dec 16, 2015 10:14:21 PM com.pega.pegarules.internal.bootstrap.PRMin
iLoader
[java] 19830421: Will load phase 2 bootstrap from Pega-EngineCode:07-10-15
