![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689989000/1c67efa3-bfe2-47d0-aee5-b5c6f0e0df14.png?itok=zBwiSjT5)
Atos Syntel
Last activity: 8 Feb 2016 5:49 EST
prpcUtils: runagent - what class should we mention for "CLASSES TO INCLUDE" parameter
I am testing the prpcUtils scripting in Pega 7.
it seems for the "runagent" argument we need the following parameters set in the prpcUtils.properties file.
############################### SETTINGS FOR AGENT MANAGEMENT TOOL ##########################
# CLASSES TO INCLUDE (REQUIRED):
# classes.included : classes to include, separate classes by commas
runagent.agentruleset=Pega-RulesEngine
runagent.agentname=PropertyOptimization
I know what to give for runagent.agentruleset and runagent.agentname parameters, what should i give for classes.included parameter.
Updated: 28 Dec 2015 12:53 EST
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2023-04/f0b84a5b-fcb2-4941-8098-9ae35047a0f1.jpg?h=a0d58e75&itok=UA_acLNT)
Hi Dilipan,
This appears to be a copy paste error in the properties file.
There should be no classes to include required for this operation.
Hope this helps.
-Jim
Amazon Corp
If we have multiple nodes in the PRPC system, will this start agents on all nodes? Is there a way to specify for it to run on a specific node?
Updated: 6 Jan 2016 9:49 EST
Atos Syntel
I need to understand how this works, i stopped the Pega-ProCom Agent AgentBulkProcessing from SMA and tried to start it using the prpcUtils script, but it didn't start.
Logs did indicate that the process was a success.
[java] 2016-01-06 09:43:06,815 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Rule Set = Pega-ProCom Agent Name=AgentBulkProcessing
[java] 2016-01-06 09:43:06,815 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Agents enabled. Finding Agent Queue (Data-Agent-Queue) for AgentBulkProcessing
[java] 2016-01-06 09:43:06,815 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Attemt :1. Finding Data-Agent-Queue instance...
[java] 2016-01-06 09:43:06,816 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Schedules not created yet for rule set Pega-ProCom
[java] 2016-01-06 09:43:07,316 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Attemt :2. Finding Data-Agent-Queue instance...
[java] 2016-01-06 09:43:07,316 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Schedules not created yet for rule set Pega-ProCom
[java] 2016-01-06 09:43:07,359 [egaRULES-MasterAgent] [ STANDARD] [ ] ( internal.async.Agent) INFO - System date: Wed Jan 06 09:43:07 EST 2016 Total memory: 547,356,672 Free memory: 234,506,144 Requestor Count: 9 Shared Pages memory usage: 0%
[java] 2016-01-06 09:43:07,816 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Attemt :3. Finding Data-Agent-Queue instance...
[java] 2016-01-06 09:43:07,816 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Schedules not created yet for rule set Pega-ProCom
[java] 2016-01-06 09:43:08,316 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Attemt :4. Finding Data-Agent-Queue instance...
[java] 2016-01-06 09:43:08,316 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Schedules not created yet for rule set Pega-ProCom
[java] 2016-01-06 09:43:08,817 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Attemt :5. Finding Data-Agent-Queue instance...
[java] 2016-01-06 09:43:08,817 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Schedules not created yet for rule set Pega-ProCom
[java] 2016-01-06 09:43:09,317 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Attemt :6. Finding Data-Agent-Queue instance...
[java] 2016-01-06 09:43:09,317 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Schedules not created yet for rule set Pega-ProCom
[java] 2016-01-06 09:43:09,817 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Attemt :7. Finding Data-Agent-Queue instance...
[java] 2016-01-06 09:43:09,817 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Schedule of Agent AgentBulkProcessing found.
[java] 2016-01-06 09:43:09,817 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Found Data-Agent-Queue instance successfully
[java] 2016-01-06 09:43:09,817 [ r000hzn0c] [ STANDARD] [ ] ( internal.async.Agent) INFO - Trying to restart agent queue in Pega-ProCom ruleset having queue number 1
[java] 2016-01-06 09:43:09,820 [ r000hzn0c] [ STANDARD] [ ] ( internal.async.AgentQueue) INFO - Pega-ProCom #1: Cannot restart queue.
[java] 2016-01-06 09:43:09,820 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - Agent Queue started successfully
[java] 2016-01-06 09:43:09,824 [ r000hzn0c] [ STANDARD] [ ] (al.util.AgentManagementUtility) INFO - No more queue items to process. Exiting the Agent Management Utility
-cleanup:
[echo] Cleaning up temp directory...
[delete] Deleting directory /xjp/temp/tmp/PegaInstallTemp-06-January-2016-09.40.45
runagent:
[echo] PegaRULES Process Commander Column Population complete.
BUILD SUCCESSFUL
Total time: 2 minutes 26 seconds
Atos Syntel
any update on this ?
Hi Dilipan,
It appears to be successful - what do you need?
There are no classes to include.
Atos Syntel
the logs says as successful, but the agent didn't start.
