Verizon
Last activity: 5 Jan 2016 8:18 EST
Problems launching Pega7 web application
I am getting the following exception when I am trying to launch Pega7 Web application.
PegaRULES Web Application Error
Message: An has occurred processing this request. Please contact your system administrator.
Unable to obtain build properties due to java.lang.reflect.InvocationTargetException: null
I have attached the log file as well. Can someone please let me know the solution for the same.
Likes (1)
Surya Narayanan s -
Citicorp Services India Private Limited
Hi Srikanth,
Could you please let us know whether this is fresh installation or upgrade?.
Please also let us know the IBM JDK version, Web Sphere application version as well.
Gowrishankar.
Verizon
Hi Gowrishankar,
It's a Fresh installation.
JDK version : 1.7
WAS Server : 8.5.5
Hi
To start with I would suggest you to check these two SA which talks about similar kind of issue
https://community.pega.com/support/support-articles/prpc-shows-websphere-error-instead-login-screen
Verizon
Hi Shantanu,
I have gone through the links shared by you . First link is not relevant to this problem and I have the required configurations mentioned in the second link.
Please let me know if there are any other fixes for my issue.
Srikanth Kodali
PEG
Hi Srinath,
Could you please check datasource configuration at WAS end? And also PRPC installed single/split schema .
Verizon
Hi Gangababu,
1) Test connection is successful for the PEGA RULES data source.
2) We have split schema configured.
Thank You
PEG
Did you create JNDI Binding Identifiers mentioned in below installation guide under "Create JNDI Binding Identifiers" to support split schema configuration?
Please refer https://docs-previous.pega.com/pega-719-platform-installation-guide-oracle-websphere
Verizon
I have created JNDI Binding Identifiers as per the document.
Check the below link, it has some useful suggestions. Ignore if you already looked at this link.
Let us know if this helps.
https://pdn.pega.com/forums/deployment-and-installation/prbootstrap-and-prapploader-fails-initialize
Verizon
Hi Pankaj,
I have all the required configurations mentioned in your link. Please suggest if I am missing any other configurations.
Thank you
Please provide the complete logfile showing the system trying to start. What database are you connecting to? You mentioned that the test connection for the PegaRULES datasource is successful. What database user are you using in the datasource? If it is not the data schema user does this user have permissions to access all tables in both the data and rules schemas as well as execute all stored procedures?
Verizon
Hi Celeste,
Please find the details below:
What database are you connecting to - jdbc:oracle:thin:@v01bmod04d.server.rbsgrp.mde:1521:GBM2C
What database user are you using in the datasource - pega_data
Verizon
Hi Celeste,
What database user are you using in the datasource - pega_data . This user has permissions to access all tables in both the data and rules schemas as well as to execute all stored procedures.
Please provide the complete logfile showing the system trying to start - I will attach the log file separately.
Verizon
I can't able to attach the file. Please suggest on how to attach the log file.
If you click 0n the "Use Advanced Editor" button in the top right of the reply box then at the bottom right of the reply box there is a paperclip Attach that you can use to attach files. I'm assuming that pega_data is the name of the data schema. That database user should have the correct permissions to start the system if you setup the bindings correctly. The full startup log should show us if the bindings are the issue (perhaps at the wrong scope?) or something else.
