Capgemini
Last activity: 8 Jan 2016 3:58 EST
Embedding an application with a Pega gadget using Pega Web Mashup
As part of Web Mashup embedding into a webpage using authentication of session management and running the gateway servlet, we are unable to view the links which are posted on PDN.
Please find the attachment which has links which do not direct to the required content.
Could you please provide the links or the documents which explains running a Gateway servlet and Mashup authentication.
Hi Kishore,
The following PDN article talks about Pega Web Mashup https://collaborate.pega.com/discussion/pega-web-mashup-iac-and-browser-backforward-navigation-button-behavior
You can find the links and references if you expand the Basics , Advanced , Troubleshooting to know more about Pega Web Mashup.
Regarding your question, the following three links would help you.
https://pdn.pega.com/developing-composite-applications-pega-web-mashup
https://pdn.pega.com/configuring-pega-web-mashup-authentication-composite-application
https://pdn.pega.com/installing-pega-composite-gateway-servlet-pega-web-mashup
Please let me know, if this helps
Gowrishankar.
