JP
Last activity: 14 Nov 2016 9:15 EST
Is there any way to set default filtering on grid repeat filtering option?
Is there any way to set default filterings on grid repeat filtering option?
Updated: 3 Mar 2016 2:12 EST
Hi Jun,
There is no way to utilize the filter options by default. Also, the page created for filtering option is Auto-Generated, which couldn't be controlled.
Hi Jun,
Could you please elaborate on your query, specifically, what shall we infer by "default filtering"?
A sample (OOTB) use case for filtering in grids is available in the UI Gallery. Click on: Designer Studio -> User Interface -> UI Gallery -> Filtering.
Updated: 23 Feb 2016 20:23 EST
JP
JPMC
Hi Jun, Am not sure if thats possible, i feel its not possible. However one easy way out is to have a filter criteria shown above the grid and make use of that values to show the data in the grid. So those values can be pre-populated in a pre-datatransform / activity and based on that the grid would be pre-filtered...
JP
Hi Ashish,
That will be my second choice. Thank you for your response.
virtusa
here we have an option for repeating grid that we can take source from the report defination and u can filter the values in the report defination and u can get only some values here
JP
Hi Prasanth,
If you filter the values in the report definition, you can only get the values from there. I need to show the unfiltered values when users change the filtering on the grid repeat.
JP
I guess there is no way to set a default filtering on a grid repeat column now. I will make a filter criteria above the grid repeat for this time.
Will Pega have a plan to implement this filtering options?
Hi Jun,
JP
Thanks, Pankaj. I will make a filter criteria above the grid repeat for this time.
Virtusa Consulting Services
Hello All,
Is there a way where I need to make this filter overlay as expandable? So that user will be able to expand it and see the complete row value and then make a select.
Vijendra HD
