TSYS
Last activity: 16 Mar 2016 11:15 EDT
Pass parameter from navigation rule to flowaction
Is there any option pass parameter from a navigation rule to a flow action? PDN says that this feature is available in 7.1.8 but I dont see it when I add a flow action within a navigation rule.
TSYS
HI Pankaj,
Thanks for the suggestion . I was referring to below PDN link. I don't see the out of the box feature as mentioned in the below link.
https://community.pega.com/support/support-articles/passing-parameter-flow-action-navigation
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689966000/18c433f8-1e18-4340-81ce-2be99ef4528f.jpg?itok=rBmW0AVs)
JPMC
Hi Nagarajan,
Please provide us the pdn link that you were refering, which would help us to get you the correct answer.
I remember previously, this option was not available, so all over our application we are calling our own JS function in "Run-Script" method with parameters
Sorry, my bad the above one is for Flow call.
For calling Flow-Action, you have to use one of the action "Local-Action" & "Open Local Action" according to requirement. And as, Flow-Action doesn't accept any parameters. Set you parameters in a page before calling the Local-Action and utilize the same page again in Flow-Action. Hope it helps.
TSYS
HI Pankaj,
TSYS
Hi Pankaj,
Whatever you suggested is one way of passing parameter to a flowaction from the navigation rule? If you see the below PDN link, it says there is a new feature available now and I was looking for that,
![](/themes/custom/pegacc_theme/images/user-icon.png)
Hi Nagarajan,
I saw the comments to the tagged Support Article, did you get a chance to look at the Help document suggested?
https://community.pega.com/sites/default/files/help_v72/procomhelpmain.htm
Let us know if this helps.
Lochan
TSYS
Yes, I did referred to the help and there is no details in help on this item (pass parameter to flow action from navigation rule )
Nagarajan Kadhiresan
