Full text search of work objects: how to add columns of data to search results?
I am upgrading from 6.1 to 7.1.8. I have the following requirements implemented in 6.1
Show these columns in the search results from the Work Object search gadget:
- Case Type (class of work object)
- Work ID (pyID)
- Work object status (.pyStatus )
- Originator (OperatorID who created the work object)
- Creation Date (when object was created)
- Updated By (operator who last updated the work object)
The Problem
I cannot seem to implement this requirement, for two reasons:
- I can retrieve the Originator but I cannot display it
- I cannot retrieve data for Creation Date or Updated By
Details
In 6.1, work search results are returned in instances of Data-Work-Summary. This table maps the columns in my requirements to the corresponding properties in Data-Work-Summary and Work-
Column |
Data-Work-Summary |
CaseType |
pyClass |
WorkID |
pyID |
- Work ID (pyID)
The Problem
Details
Column |
Data-Work-Summary |
CaseType |
pyClass |
WorkID |
pyID |
WorkObjectStatus |
pyStatus |
Originator |
pyOriginator |
CreationDate |
pyCreatedOn |
UpdatedBy |
pyUpdateOperator |
In 7.1, work search results are returned on a page, of Code-Pega-List, called pySearchResultsWork
They are displayed in section Work-.pyShowResultsInNewWindow, with the following columns:
At runtime, the results list, pySearchResultsWork.pxResults, appears to be of Work- on the clipboard. However, it is actually of either Pega-Search-Work-Results or Data-Find-ResultsWork
The mapping of columns to properties is as follows:
Column |
Property |
CaseType |
pyCategory |
Description |
pyLabel |
ID |
pyID |
Status |
pyStatusWork |
Updated |
pxUpdateDateTime |
To match my requirements, I remove Description and Updated/pxUpdateDateTime. No problem.
The Problem Starts Here
Next I choose fitting properties for the columns I need to add. I had to try a few. We get this mapping (including several alternatives that I tried):
Column |
Property |
Problem |
CaseType |
pyCategory |
ok |
ID |
pyID |
ok |
Status |
pyStatusWork |
ok |
Originator |
pyOriginator |
pxCreateOperator |
Null data (see below) |
pxOrigUserID |
Creation Date |
pzWorkCreatedOn |
pxCreateOperator |
Updated By |
pxUpdateOperator |
The reason for the invalid property references is the class of the List .pyWorkResults - which is Work-:
Those properties don't exist in Work- because they are from Pega-Search-Work-Results.
I tried changing declaring pyWorkResults as Pega-Search-Work-Results without success. That fails because pyWorkResults is actually of $ANY. And I can't override pyWorkResults in my own ruleset because it starts with "py".
As for the alternate properties I tried above, they return no data:
I checked the work objects in the results to ensure that those properties do, indeed, have values. It would take some strange coding choices to prevent a work object from being created with those properties populated, but it's best to be sure. The following screenshot is excerpted from the clipboard with work object G-4 open:
I have looked for a way to add these columns to the results that are returned, but I run into a wall of Final rules and, ultimately, a call to the search service, which is a SOAP service and opaque to me.
These are the properties returned by search results.
At the risk of sounding flippant, I'll observe that I can retrieve the class and ID five different ways each, but I cannot retrieve the properties I am looking for.
Summary
- I can retrieve the Originator as pzWorkCreatedOn, but I cannot display it because I can't add pzWorkCreatedOn to a rule
- I cannot retrieve the creation date or update operator
I originally submitted a less-detailed version of this request to GCS. I was directed to post my question here.
I am hoping that someone can tell me how to configure search to
- populate the missing data
- populate a value for Originator into a property that I can use
If not, then I think these issues are odd design/feature choices at best. I didn't dive into it, but I believe some of the other values returned by the search are also invalid for Work- and would therefore run into the same catch-22 if one tried to display them.
