virtusa
Last activity: 27 Mar 2017 15:59 EDT
gmail connectivity
i have requirement that i need to send mail to end user gmail how can i do that??/
virtusa
ya i got answer by changing the port number 587 and placing the ip address not the domain name i think some problem with the mapping them
Hi Prashanth,
This is a good starting point for email: https://pdn.pega.com/about-email
Many of the linked articles look to have been written for 5.x, but should still give you a general idea as to how things work. If you have a more specific question, please let us know.
prasanth kumar has stated on a new thread of same topic (which has been closed) the following:
"ya actually i am not able to find the option of email accelerator"
Is anyone able to assist him further? Thank you in advance!
Well, the PDN is quite out of date, but it still gives the correct location of the email accelerator, which is currently called "Email Wizard"
Main (Designer Studio) Menu -> Integration -> Email -> Email Wizard
virtusa
ya i am able to create the inbound and outbound emails for the wizard after that what process i need to do get the emails send out of the organization can plz let me know?>>
Hi Prasanth,
I am assuming you already have the email account in your application since you ran the wizard already.
After that you just need to use Send Email smart shape in the process to send email.
Please find the below PDN article for more details on this smart shape configuration.
https://community.pega.com/sites/default/files/help_v72/procomhelpmain.htm management/process-modeler/cm-configuring-send-email-shape-tsk.htm
Let us know if this helps
virtusa
i could not see pdn page u have posted plz place a correct link
Can you try copy paste the entire URL instead of clicking Hyperlink. Link is not generated correctly due to spaces
virtusa
no i am not able see when even i copy paste the link
Ok. Check out this link and let us know if this is accessible.
https://community.pega.com/sites/default/files/help_v719/procomhelpmain.htm
virtusa
ya its working pankaj
virtusa
the link is working but i am not able to get the output can anybody help me with this??
PEG
What is the issue you are getting? Can you paste the error screenshot as well as configuration screen shots.
virtusa
the thing is i have created an inbound mail and outbound email using the email wizard and next of it not able to proceed so plz let what i can do further??
virtusa
JP
You've set up an email account for sending / receiving emails from PRPC.
Now, you need to write an email, a correspondence in PRPC, and send it out, usually it is performed by an agent.
For more about email correspondence, see https://pdn.pega.com/correspondence
And there is a good online Pega Academy course, which describes how to configure email notification feature in PRPC.
You can find this course at Pega Academy site.
go to PDN home page > Academy > My Self-Study, then search SSA course.
Incessant Technologies
Hi Prasanth,
As you said that you completed Email account setting, and I hope you also verified the email connectivity, then to send mail to customer [probably GMAIL account as you said initially] you need to decide the source rule which will send/generate the mail.
By default PRPC can send mail (correspondance) from following rules -
- Assignment shape.
- Send Email flow shape.
- When SLA is reached.
- "Send Correspondence” flow action
Choose any from above list which is suitable for your purpose. Hope this answer your question
virtusa
Chunzhi Hong what my req is all i need send email outside the organization some thing from my prpc application
PEG
Hi Prasanth,
Can you use SendEmailNotification OOB activity to send email from PRPC?
virtusa
ya i have found the activity where i need to call the flow so that i that it will ask for the email adress and mail content to send it to a particular mail
virtusa
PEG
In above screenshots you used gmail as sender, in recent screenshot you used yahoo account. Could you please clarify which email account you are using?
virtusa
see i tried whether is it is working with atleast the yahoo or not even i face the same issue with the gmail even
PEG
Which version of PRPC you are in? Please paste the screen shot of Email Account configuration with gmail .
virtusa
rajesh i need to achieve on a send email flow shape
virtusa
Hi Prasanth, Does the less secure apps have access under the account which your are trying to configure ? To explicitly enable "less secure apps" in gmail settings got to: google.com/settings/security/lesssecureapps.
PEG
Hi Prasanth,
Can you give User ID and password in Sender configuration and give it a try?
virtusa
i have already made it on
virtusa
i have tried i cant find the change gangababu
PEG
Please try creating DSS setting as mentioned in below article.
https://community.pega.com/support/support-articles/smtp-connectivity-test-fails-email-account
virtusa
even i place them same i not able to connect to email server
virtusa
i have already tried even with it but not able reach it out
PEG
Any proxy setting available in your network? Please check with your admin team regarding this.
virtusa
i am facing the same issue even i try at home
Is the server hosted on your laptop? If not and you are connecting to it through the internet (or an intranet), testing the connection while at home will not make a difference.
virtusa
yup it is a vmwareplayer i am having prpc image in that vm
Okay, that sounds like it is related to the problem. I'm not familiar with running Pega on VMware and connecting to gmail... But there is likely something that needs be configured in VMware for that to work.
Prasanth,
By any chance, is this a Pega Academy PVS?
virtusa
can u tell me what type of configuration u need to do for this
I'm not exactly certain, but perhaps this will help:
Changing the Networking Configuration
I wonder - Can you ping smtp.gmail.com from within the VM successfully?
virtusa
david can tell what is this pvs??
Pega Academy uses "Personal Virtual Systems" - which are just ready-to-go virtual machines, I believe using VMware - which is why I asked.
So, is this a virtual machine provided to you by Pega Academy?
virtusa
ya the vm comes with the package of the pega with all the virtual image of prpc and vm player everthing all it comes as a package
Updated: 6 Apr 2016 10:27 EDT
I found the following post in the Pega Academy forums that is related to this: https://pdn.pega.com/forums/prpc-integration-specialist/unable-attach-gmail
Select the option "Bridged:connect directly to physical network"
option is available under Settings -Network Adapter - Network Connection
If you're not using the option as mentioned above, I'd suggest trying that. You may also want to reach out to folks at Pega Academy, as they will know more about how these VM should be configured.
For self study support, I believe you can contact [email protected]
virtusa
United health group
Can u please post that screen shot of configuration. I too have the same issue.
Swiftrinity
Hi Can you please post the screenshot I have having same issue
