AIG
Last activity: 30 Mar 2016 15:47 EDT
Pega Server Startup error after deployment -62SP2 on Z OS with DB2
Pega rules Server start up error as shown below . Please advise what should be corrected ?
Few noted errors :
javax.resource.ResourceException: Failed to execute asynchronous task: java.lang.Exception: JNDI API lookup failed for factory: javax.naming.NameNotFoundException: Name comp/env/jms/tcf not found in context "java:"., javax.naming.NameNotFoundException: Name comp/env/jms/tcf not found in context "java:".
com.pega.pegarules.pub.PRRuntimeException: Method Invocation exception
com.pega.pegarules.pub.PRException: Failed to execute Resource Adapter function: UsageDaemon {ClientID=UsageDaemon, ExecutionDelay=221, NodeID=58b8ac46411c934617bad8eae2399300}
Pega rules Log
com.pega.pegarules.pub.context.InitializationFailedError: PRNodeImpl init failed
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:387)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.getThreadAndInitialize(PRSessionProviderImpl.java:1501)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineStartup.initEngine(EngineStartup.java:611)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._initEngine_privact(EngineImpl.java:165)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.doStartup(EngineImpl.java:138)
Few noted errors :
Pega rules Log
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.doStartup(EngineBean.java:120)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:611)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:349)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:390)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingException(PRBootstrap.java:412)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.doStartup(EngineBeanBoot.java:130)
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.doStartup(Unknown Source)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener._contextInitialized_privact(WebAppLifeCycleListener.java:259)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener.contextInitialized(WebAppLifeCycleListener.java:167)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:439)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
at com.ibm.ws.webcontainer.webapp.WebApp.notifyServletContextCreated(WebApp.java:1721)
at com.ibm.ws.webcontainer.webapp.WebApp.commonInitializationFinish(WebApp.java:388)
at com.ibm.ws.webcontainer.webapp.WebAppImpl.initialize(WebAppImpl.java:299)
at com.ibm.ws.webcontainer.webapp.WebGroupImpl.addWebApplication(WebGroupImpl.java:100)
at com.ibm.ws.webcontainer.VirtualHostImpl.addWebApplication(VirtualHostImpl.java:166)
at com.ibm.ws.webcontainer.WSWebContainer.addWebApp(WSWebContainer.java:732)
at com.ibm.ws.webcontainer.WSWebContainer.run(WSWebContainer.java:645)
at java.lang.Thread.run(Thread.java:767)
Caused by:
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1030)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:758)
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:379)
... 32 more
Caused by:
java.lang.reflect.InvocationTargetException
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1028)
... 34 more
Caused by:
com.pega.pegarules.pub.PRRuntimeException: PRRuntimeException
at com.pega.pegarules.monitor.internal.UsageDaemonImpl.initialize(UsageDaemonImpl.java:518)
at com.pega.pegarules.session.internal.async.Agent.start(Agent.java:1393)
at com.pega.pegarules.session.internal.mgmt.PRNodeImpl.startNode(PRNodeImpl.java:1475)
at com.pega.pegarules.session.internal.mgmt.PREnvironment.finishInit(PREnvironment.java:532)
... 39 more
Caused by:
From: (BBC61483F4D93A9B100C3D9E20D75497B:(PREnvironment))
at com.pega.pegarules.session.internal.async.BatchUtils.callRAClient(BatchUtils.java:151)
at com.pega.pegarules.monitor.internal.UsageDaemonImpl.initialize(UsageDaemonImpl.java:516)
... 42 more
Caused by:
java.lang.Exception: Caught exception while executing Interaction Function, javax.resource.ResourceException: Failed to execute asynchronous task: java.lang.Exception: JNDI API lookup failed for factory: javax.naming.NameNotFoundException: Name comp/env/jms/tcf not found in context "java:"., javax.naming.NameNotFoundException: Name comp/env/jms/tcf not found in context "java:".
at com.pega.pegarules.resadap.RAClient.execute(RAClient.java:217)
at com.pega.pegarules.session.internal.async.BatchUtils.callRAClient(BatchUtils.java:147)
... 43 more
Caused by:
at com.pega.pegarules.ra.priv.PRResourceDriver.invokeAsyncResource(PRResourceDriver.java:199)
at com.pega.pegarules.ra.priv.PRResourceDriver.call(PRResourceDriver.java:108)
at com.pega.pegarules.ra.spi.PRManagedConnectionImpl.call(PRManagedConnectionImpl.java:292)
at com.pega.pegarules.ra.cci.PRConnectionImpl.call(PRConnectionImpl.java:128)
at com.pega.pegarules.ra.cci.PRInteractionImpl$1.run(PRInteractionImpl.java:90)
at java.security.AccessController.doPrivileged(AccessController.java:413)
at com.pega.pegarules.ra.cci.PRInteractionImpl.execute(PRInteractionImpl.java:87)
at com.pega.pegarules.resadap.RAClient.execute(RAClient.java:206)
... 44 more
