United Health Group
Last activity: 5 May 2016 10:08 EDT
Flow issues in pega 7
Unable to edit flows in pega 7 system upgraded from 6.2 SP2
Virtusa Consulting Services Pvt. Ltd.
Hi Naveen,
Please share the screenshot of the error that you are getting.
Goutham
United Health Group
That error is not that helpful to pinpoint the problem. But, looks like there are few mandatory fields which are missing in on the flow rule might be in properties of flow shapes or other tabs in the rule. Can you open each shape and see if anything is missing in them and also check the other tabs
United Health Group
Thats the problem here. we are not getting any kind of useful error messages in the UI and the flow required parms in all the shapes are also specified. just posted this to know whether there are any others who experienced this kind of issue. By the way this is happening on the upgrade system from 6.1 SP2 to 7.1.9.
Then, I am not sure of it Naveen. Never done upgrade and didn't see any issue like this. Did u find any useful information on tracer/ logs when opening the rule?
Any one else know anything about this?
Does this happen for new flows or just the existing flows? If only for existing flows, have you run the upgrade tools from pega 7?
United Health Group
This issue happens to the existing flows and we are not able to create new flows. we ran all the tools that we got from pega related to upgrade.
Thanks for the clarification. Now start with simpler case, what errors are you seeing when you say not able to create new flows? Can you try OOTB pega login first? And then your own user?
United Health Group
Yes we tried that as well. even we are not able to update any existing pega flows in private checkout mode. For new flows after we gave the Class etc clicking on create button doesnt do anything.
