Starter Flow Issue
We made 2 flows ( Flow1, Flow2 ) with "Creates a new work object" checked. So pyCanCreateWorkObject is true.
Both the flows is being listed under Create Menu. By mistake or over sight it moved to prod. Now we saved Flow 2 in next ruleset version and unchecked "Creates a new work object" and made it unavailable too. But the datapage, D_StartingFlows, still pulls Flows under Menu. Deeper analysis shows that the process pulls all flows with pyCanCreateWorkObject true irrespective of the ruleset version. Which I see is not right. If the latest version of the flow is false, it should not be pulled by the datapage.
We are in Version 8.5.1. Is this a known bug?
