Capgemini Financial Services
Last activity: 18 Apr 2016 21:13 EDT
Unable to launch Virtual Box
When I try clicking on the Virtual Box icon on my desktop, it will not run. I have run the 'Repair" option. I have uninstalled and reinstalled the program. All to no avail. I have VM Ware v12.xx loaded. Does this compete with VB?
I run W7, 64 bit. I'm trying to start PME 7.13.
Any suggestions?
Thanks.
Updated: 19 Apr 2016 5:58 EDT
That part was not occurring on my machine. However, I seem to be operational so far. It dawned on me that I might need to disable my Norton 360 before trying to install. It worked!
Thank you very much for your input these past few days. I appreciated all of it.
Cheers !
Larry Madson
any errors? did you check the task manager to see if the process is actual running? maybe checking windows event manager to see if there is anything there. I assume you are trying to run some VMs from PegaAcademy, right?
Updated: 18 Apr 2016 5:14 EDT
I am trying to run the Pega Marketing Enablement 7.13 ML9.vbox
No errors appear and nothing shows up in Task Manager.
I did notice that when I installed the program, it placed the file in C:\Programs\Oracle\VirtualBox. When I tried installing another time I directed it to place it in C:\Programs (x86)\Oracle\Virtual Box. Unfortunately, it did not make a difference.
I came across a suggestion from a post in the Virtual Box forum.
Some had been successful using a run command “C:\Program Files\Oracle\VirtualBox\VBoxmanage.exe startvm PegaMarketingEnablement7.13ML9.vbox (I am not sure if the way I have written this string is correct as far as where spaces belong)
When I tried to download this onto my company laptop, it flagged this as corrupt and stopped the download.
I wasn’t successful in running this. I have deleted the program and reinstalled this program around six times
Appreciate your responding
Cheers !
Larry Madson
Updated: 18 Apr 2016 5:15 EDT
I forgot one other thing.
When trying to uninstall VBox I get this error: I did a search and could not find this anywhere.
Cheers !
Larry Madson
did you install the latest version of virtualbox? Can you see the virtualbox manager?
Updated: 18 Apr 2016 5:16 EDT
Kevin:
The version I downloaded is Proprietary information hidden1
I also downloaded the VB Extension Pack.
The site I went to is the link on page 2 of the VM Quick Start Guide.
I do have an icon on my desktop; is this the VB Manager you mentioned? I am attaching a word doc showing the applications that were loaded into Programs\Oracle\VirtualBox.
I have a clarification to make. The error message I sent earlier appeared when I tried to “Repair” or “Change” prior to uninstalling.
Cheers !
Larry Madson
Hi Larry,
You may have better luck posting to the Pega Academy forums (https://collaborate.pega.com/discussion/pega-academy-down) or reaching out to [email protected] as they normally handle these types of issues.
Updated: 18 Apr 2016 10:42 EDT
Thanks, I appreciate the feedback.
Cheers !
Larry Madson
Cheers !
Larry Madson
You are welcome! Please mark your question complete! So the culprit is anti-virus program.
