RuleTek
Last activity: 24 Aug 2017 9:43 EDT
How can you restrict file attachments by extension type for an entire application? (such as .exe)
To meet a security requirement, we are trying to restrict file attachments uploaded in our application to not allow files of certain extension types. I have found several places in PRPC's base application that could be changed to enforce this, but they are all rules with the pz- prefix, and therefore can't be saved into our application. Examples are pzFileUploadGadget and pzDragDopMultiFileUpload.
Is there a better way to handle this security requirement?
Hi Justin
The activity your specified "pzFileUploadGadget"has a call to CallVirusCheck which is a dummy activitiy and available .
You can twig this activity to check the extension of the file and set message accordingly. Hope this helps.
Manash Pratim Chaliha
Agree with Santanu I guess that is one option to override and add some validation. But the intention of this CallVirusCheck is to do custom implementation for virus check.
But as of the existing implementation this is the only extension available.
Rabobank
I have implemented this requirement by adding an access-when rule which calls a decision table to verify allowed file types.
I used a function like: @String.whatComesAfterLast(.pxAttachName,'.')
Then refer this access-when rule on the access role to object of the Data-WorkAttach-File class, in the Write Instances field.
As soon as the system tries to save the attachment, it wil check the access-when rule and decision table, and will stop the object from saving and returns an error message.
This save happens very soon after the CallVirusCheck extension point, so it seems similarly safe.
Bank Of America
I have followed the same approach but it's not working .
I have attached the screenshots , please help if i am configuring something wrong.
Pratheep Kumar M S Vamshi Vaddiraja Ludovic Lopes Shikhar Nigam Manash Pratim Chaliha and 2 More
Hi Mayank,
You may also refer this discussion link as a reference in the new thread
We have also sent you a private message opening up a communication channel in case you have any further questions.
Express Scripts
I have the same requirement, was this solved?
Thanks!
