Cognizant
Last activity: 4 May 2016 3:22 EDT
Please help me on running BIX extraction tool
I have recently installed BIX in PEGA 7.1.8 Version. Now, I would like to perform BIX extraction process. In order to do that, I created a new extract rule by navigating through Records --> SysAdmin --> Extract
I created a new extract rule called POCBIX
I configured the properties and choose the output format to Database Schema. So whatever the output generated that will be stored directly into Database. So, I selected Actions --> click on Run
Now I want to generate schema DDL. So that I can download the DDL scripts and execute them on target database where I want to store the output values. But there is a mandatory field prompting for "Enter schema Path with file name" value. I'm not sure what type of value we have to produce in this field. I tried to search for a syntax in PDN and other forums. But no luck.
Appreciate your help.
Jayavardhan
