Vistronix
Last activity: 24 May 2016 17:28 EDT
Is there a defect for applying a disable privilege to a link control in PRPC 7.1.9?
After applying a privilege to a link control to disable it for certain users, the link is disabled at all times, regardless of whether the user holds the privilege or not. After looking in the product help, there is no mention of this field. Is this a product defect? There is a workaround to use the function to check for a privilege in a when rule, in the disable field, however.
We are using PRPC 7.1.9.
This is all there is for General Properties in Help:
3. Complete the Cell Properties panel— General tab
Complete the General tab.
Field |
Description |
Visible |
Optional. Select to determine when the link appears. |
Field |
Description |
Visible |
Condition |
If you selected Other Condition for the Visible field, complete this field.
As a best practice, use the Condition Builder to edit this field. Click ( An link that is not visible is also disabled and cannot be clicked. |
Run on Client? | Appears when you enter a simple expression in the Condition field. Select to cause evaluation and execution of the condition each time the value of a property stated in the condition changes. If unselected, the expression is evaluated and the condition executed when the form is initially presented and whenever the form is refreshed. |
