7.2 How to restrict access to specific Data class
Requirement:
There is a data table contains sensitive information and the access to the data table should be granted per access role.
At a first glance, it looks simple enough to implement the requirement by creating an ARO which gives access (Read instance=5) to the specific data class and grant the ARO to desired Access Groups.
However, it turns out that even users belongs to Access group that doesn't have the ARO still can open records of the data table.
It seems that OOTB ARO defined on "Data-" class plays a role here, below is my test results.
Access Group | Granted AROs | Expected | Test Result |
MyApp:Managers | "Data-" (Read instance=5) |
Can open any records of any data class that inherits from "Data-" class. | As expected. |
MyApp:Workers |
"Data-" (Read instance=5) "Data-Sensitive" (Read instance=0) |
Requirement:
MyApp:Workers |
Can open any records of any data class that inherits from "Data-" class, except "Data-Sensitive". | Can open any records of "Data-Sensitive" class. |
MyApp:Visitors | "Data-" (Read instance=0) |
Can NOT open any records of any data class that inherits from "Data-" class. |
As expected. Can open any records of "Data-Sensitive" class. |
Message was edited by: Chunzhi Hong Updated Test Result of "MyApp:Visitors"
