Inovar
Inovar
SA
Inovar
Posted: Apr 27, 2016
Last activity: Feb 5, 2017
Last activity: 5 Feb 2017 2:29 EST
Questions related to Case Type, Framework - Implementation (Not a coverable class)
I have created a parent Case which has 1 child case (defined in the case type as coverable case)
FW Layer
Case Type 1 (Parent) (XX-FW-Work-classA
Stage 1 (step 1) Stage 2 (step 1 , Step 2) Stage 3 (resolved)
At stage 2, step 2, I have a flow (FlowSTG2Step2) that has a shape to create the child case (Case Type 2) through the flow shape create Cases.
Case Type 2 (Child) XX-FW-Work-classB
Implementation Layer
Case Type 1 (Parent) XX-DIV-XX-Work-ClassA
At stage 2, step 2, I have referenced the FW layer flow (FlowSTG2Step2).
Case Type 2 (Child) XX-DIV-XX-Work-ClassB
Question 1- Do I always need to create the Case Type rule in imp Layer ? duplicate as framwork ?
Question 2- When I am running the application from implementation layer and reaches the stage 2 to launch the child case pega gives me an error says "XX-FW-Work-classA not a covered class". If I save the flow(FlowSTG2Step2) in implementation layer it works fine.
Qustion 3- Do I need alternate stage to launch child case ?
