Accenture Services Pvt Ltd
Posted: Apr 27, 2016
Last activity: Apr 6, 2018
SOAP service issue after update from PRPC7.1.8 to PRPC7.2
We have updated our environment from PRPC7.1.8 to PRPC7.2. Our Application server is WebSphere Proprietary information hidden. Database Oracle 11g R2.
After the update we are getting certificate error while calling SOAP service which was working fine before upgrade. We are getting below error while calling the SOAP service.
We are using SOAP APIs provided by Salesforce to fetch data using a SOAP Connector in Pega.
[ com.ibm.jsse2.util.h: PKIX path building failed: java.security.cert.CertPathBuilderException: PKIXCertPathBuilderImpl could not build a valid CertPath.; internal cause is: java.security.cert.CertPathValidatorException: The certificate issued by CN=VeriSign Class 3 Public Primary Certification Authority - G5, OU="(c) 2006 VeriSign, Inc. - For authorized use only", OU=VeriSign Trust Network, O="VeriSign, Inc.", C=US is not trusted; internal cause is: java.security.cert.CertPathValidatorException: Certificate chaining error
Could any one suggest some solution for this?
