Pass property values in between stages
Please help me how to pass the values of Properties belongs to one stage to another stage. I am using same properties in the different stages.
I feel bit wrong with the question, as properties belong to a case type which should be acccessible to all stages and flows.
If the required values are part of the flow journey, declare them as properties so that values computed in stage 1 are available in further stages.
Hi Sateesh,
Thanks for the reply. Let me elaborate my question. I have created a property with table type as local list with 5 values. I have referred that property in the sections of 1 st stage and 2nd stage. Then I have created a work item, and in 1 st stage, I have selected one value for that property from the local list. I went to second stage and now I need to pass the value selected at 1 st stage even to second stage automatically.
I have achieved this through by refreshing the section at 1 st stage and populating the value in second stage via clipboard. But I need the another method as current approach is not making me to enhance the further requirements.
Can you explain a little bit about the use case you are trying to achieve here and also what do you mean by current approach is not flexible for enhancing.
Usually properties are maintained at Case level and not Stage level, so I am not sure what is the exact issue here.
Why are you refreshing the section explicitly ? Flow action submit should automatically update the property on clipboard.
Are you trying to update property in some other way (other than Flow Action) ?
If you are maintaining the local list property value on the pyWorkPage it will display the same value in stage 2 as well.
