AIG
Pega 7.1.5 to 7.1.8 Update Issues
ECS Team -
We have received a total of 550 failed validations after running the bulk revalidate and save utility. Below are some of the unique exceptions from the "Failed Validations" report. Could you provide more insight into it? Have you seen issues of below sort?
You can refer to SR-A20700.
InvalidParameter Class not defined in dictionary. Pages & Classes validation. Database-Instance-NotFound RULE-OBJ-ACTIVITY WORK- XYZATTACHFILE #20150623T171840.992 GMT PegaEL-InvalidExpression When used with a "For Each Embedded Page" option, the Step page should reference a list or group property Validate-InvalidForPreReq Rule-Message: Please Select a Version Problem executing pzAssemblePreprocess for RULE-HTML-SECTION XYZ-FW-MNPFW-WORK-SUBMISSION QUICKSUMMARYPRINT #20160106T125735.329 GMT. java.lang.NullPointerException Validate-InvalidForPreReq webwb/XYZSave.png myAssignWorklist.pxAssignedUserName is not a valid Report-Definition Field. Problem executing pzAssemblePreprocess for RULE-HTML-SECTION XYZ-FW-MNPFW-WORK-SUBMISSION QUICKSUMMARYPRINT #20160106T125735.329 GMT. java.lang.NullPointerException Validate-InvalidForPreReq webwb/XYZSave.png myAssignWorklist.pxAssignedUserName is not a valid Report-Definition Field UnknownProperty XYZ-FW-MNPFW-Work-Submission.ConfirmationExcelDisplay Problem executing pzAssemblePreprocess for RULE-HTML-SECTION XYZ-FW-MNPFW-WORK-SUBMISSION QUICKSUMMARYPRINT #20160106T125735.329 GMT. java.lang.NullPointerException Validate-RecordDoesNotExistForUse PDFDocActionSummaryNBAPAMLabels Validate-InvalidForPreReq webwb/ExportToExcel Validate-InvalidForPreReq webwb/MapIndicatorVector.png Validate-RecordDoesNotExistForUse XYZ-FW-MNPFW-Work.IsScreenTerritoires is not recognized as either a valid Rule-Obj-When or Rule-Obj-Property rule. |
