Pega Update from 7.1.5 to 7.3.1 System not starting after Update
hi ,
Getting below error and system is not starting.
Pega 7.1.5 to 7.3.1 Update on Tomcat7/Oracle12C/RHEL
Show More
hi ,
15:57:52,838 [ocalhost-startStop-1] (ervlet.WebAppLifeCycleListener) INFO - System Start Date: Thu Dec 28 15:57:52 CST 2017
15:57:52,845 [ocalhost-startStop-1] (ervlet.WebAppLifeCycleListener) INFO - PegaRULES Web Tier 7.10 (ML5)
15:57:52,845 [ocalhost-startStop-1] (ervlet.WebAppLifeCycleListener) INFO - coreAssemblyCached_715_230: 2014-05-06 18.03 EDT
15:57:52,845 [ocalhost-startStop-1] (ervlet.WebAppLifeCycleListener) INFO - http://camscm/svn/PRPC_core/branches/integration/715/dev/core (88625)
15:57:52,845 [ocalhost-startStop-1] (ervlet.WebAppLifeCycleListener) INFO - Now starting the PegaRULES Web Tier...
15:57:52,868 [ocalhost-startStop-1] ( context.web.WebEnvironment) INFO - Web tier using local JNDI context
factory = org.apache.naming.java.javaURLContextFactory
url = <not specified>
path = java:
15:57:52,868 [ocalhost-startStop-1] ( priv.context.JNDIEnvironment) INFO - Web-tier default Engine bean name is EngineBMT
15:57:53,339 [ocalhost-startStop-1] ( basic.config.SettingsImpl) INFO - prconfig.xml merged with prconfig entries in Data-Admin-System-Settings
15:57:53,589 [ocalhost-startStop-1] (ion.internal.PRGenProviderImpl) INFO - Using Hybrid Virtual Rules Table implementation
15:57:53,589 [ocalhost-startStop-1] (ion.internal.PRGenProviderImpl) INFO - VTable dispatches rules for 7 Aspects: 'Action, Alias, Collection, Input, Model, Validate, When'.
15:57:53,589 [ocalhost-startStop-1] (ion.internal.PRGenProviderImpl) INFO - ABA[UNKNOWN] dispatches rules for 1 Aspect: 'Stream'.
15:57:53,688 [ocalhost-startStop-1] (ion.internal.PRGenProviderImpl) INFO - invokeDynamic instrumentation for inlining is enabled
15:57:53,689 [ocalhost-startStop-1] (ion.internal.PRGenProviderImpl) INFO - Assembly Version: 1402912254
15:57:53,692 [ocalhost-startStop-1] ( priv.context.JNDIEnvironment) INFO - Enterprise-tier default Engine bean name is EngineBMT
15:57:53,693 [ocalhost-startStop-1] (r.context.EtierEnvironmentImpl) INFO - Enterprise tier using local JNDI context
path = java:
15:57:53,872 [ocalhost-startStop-1] ( internal.archive.ParUtilsImpl) INFO - Setting archive staging directory: /app/logs/pega/tmp/RuleMgmt
15:57:53,872 [ocalhost-startStop-1] ( etier.impl.EngineStartup) INFO - JVM Information:
15:57:53,872 [ocalhost-startStop-1] ( etier.impl.EngineStartup) INFO - Vendor: Oracle Corporation, JVM version: 1.7.0_80
15:57:53,872 [ocalhost-startStop-1] ( etier.impl.EngineStartup) INFO - VM Name: Java HotSpot(TM) 64-Bit Server VM(build 1.7.0_80-b15)
15:57:53,872 [ocalhost-startStop-1] ( etier.impl.EngineStartup) INFO - Host OS Information:
15:57:53,872 [ocalhost-startStop-1] ( etier.impl.EngineStartup) INFO - OS: Linux, version: 2.6.32-696.6.3.el6.x86_64
15:57:53,872 [ocalhost-startStop-1] ( etier.impl.EngineStartup) INFO - Architecture: amd64
15:57:53,872 [ocalhost-startStop-1] ( etier.impl.EngineStartup) INFO - PegaRULES Enterprise Tier 7.10 (ML5)
15:57:53,872 [ocalhost-startStop-1] ( etier.impl.EngineStartup) INFO - coreAssemblyCached_715_230: 2014-05-06 18.03 EDT
15:57:53,872 [ocalhost-startStop-1] ( etier.impl.EngineStartup) INFO - Deployed in web tier only
15:57:53,872 [ocalhost-startStop-1] ( etier.impl.EngineStartup) INFO - Servlet container: Tomcat
15:57:53,872 [ocalhost-startStop-1] ( etier.impl.EngineStartup) INFO - Web server: Apache Tomcat/7.0.75
15:57:53,872 [ocalhost-startStop-1] ( etier.impl.EngineStartup) INFO - Web server environment: Tomcat
15:57:53,872 [ocalhost-startStop-1] ( etier.impl.EngineStartup) INFO - Web-tier default Engine bean name: EngineBMT
15:57:53,872 [ocalhost-startStop-1] ( etier.impl.EngineStartup) INFO - Web to Enterprise tier delegate type: pojo
15:57:53,872 [ocalhost-startStop-1] ( etier.impl.EngineStartup) INFO - Now starting the PegaRULES Engine...
15:57:53,905 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Base database information:
15:57:53,905 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Database name: omegadb
15:57:53,905 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Defined by: JNDI name
15:57:53,905 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Data source name: java:comp/env/jdbc/OmegaDS
15:57:53,905 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Minimum connection count: 0
15:57:53,905 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Maximum connection count: unlimited
15:57:53,905 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Failover database: none
15:57:53,905 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Database name: pegadata
15:57:53,905 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Data source name: java:comp/env/jdbc/PegaRULES
15:57:53,905 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Default Schema: MNPDATA
15:57:53,906 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Base database information:
15:57:53,906 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Database name: pegarules
15:57:53,906 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Defined by: JNDI name
15:57:53,906 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Data source name: java:comp/env/jdbc/PegaRULES
15:57:53,906 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Minimum connection count: 0
15:57:53,906 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Maximum connection count: unlimited
15:57:53,906 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Failover database: none
15:57:53,906 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Default Schema: MNPRULE
15:57:53,906 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Database name: sigmadb
15:57:53,906 [ocalhost-startStop-1] (l.access.ConnectionManagerImpl) INFO - Data source name: java:comp/env/jdbc/SigmaDS
15:57:54,017 [ocalhost-startStop-1] ( external.timers.CpuTimer) INFO - CPU timers set to TOTALSONLY. Use prconfig setting 'initialization/CpuTimerLevel' with one of [FULL, TOTALSONLY, NONE] to modify.
15:57:54,020 [ocalhost-startStop-1] (.timers.EnvironmentDiagnostics) INFO - Using Java 1.5 Thread.getAllStackTraces() for thread dumps
15:57:54,086 [ocalhost-startStop-1] (.access.PageDatabaseMapperImpl) INFO - DeflateStreams is turned ON.
15:57:54,117 [ocalhost-startStop-1] (pboard.StorageStreamCommonImpl) INFO - engineCodeVersion: 07-10-11
15:57:54,279 [ocalhost-startStop-1] (ernal.access.DataSourceManager) ERROR - Unable to obtain DataSource for wdm; javax.naming.NameNotFoundException: Name [jdbc/wdm] is not bound in this Context. Unable to find [jdbc].
15:57:54,322 [ocalhost-startStop-1] ( internal.mgmt.PRNodeImpl) INFO - Using codeset version and timestamp map: {asposecellsv2=01-01-01@2016-06-17 23:16:00.0, pega-enginecode=07-10-11@2017-12-09 00:41:00.0, asposewordsv1=01-01-01@2016-06-17 23:18:00.0, customer=06-01-01@1969-12-31 18:00:00.0, asposepdfv3=01-01-01@2017-06-03 00:09:00.0}
15:57:54,498 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - Generated source : file://runtime:/PRGenJava/
15:57:54,498 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - Generated classes: file://runtime:/PRGenClasses/
15:57:54,498 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - Web-tier real root path: /app/tomcat7/webapps/prweb
15:57:54,498 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - Web-tier temporary path: /app/tomcat7/work/Catalina/localhost/prweb
15:57:54,498 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES real root path: /app/tomcat7/webapps/prweb
15:57:54,498 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES effective root path: file://default:/
15:57:54,498 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES effective temp path: /app/logs/pega/tmp
15:57:54,498 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - Using genSourcePath: file://runtime:/PRGenJava/
15:57:54,498 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - Using genClassPath (database): pegajdbc://491404590:1/
15:57:54,498 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - Using genClassPath (files): file://runtime:/PRGenClasses/
15:57:54,498 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - Using external classes in: <not using external classes>
15:57:54,498 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - Using external jars in: <not using external jars>
15:57:54,576 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - Servlet classes: /app/tomcat7/lib/servlet-api.jar
15:57:54,577 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - JSP classes: /app/tomcat7/lib/jsp-api.jar
15:57:54,577 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - EJB classes: (none)
15:57:54,577 [ dlwsawcm36532] (rnal.mgmt.InitialConfiguration) INFO - JMS classes: (none)
15:57:54,819 [ dlwsawcm36532] (rnal.access.CacheContainerImpl) INFO - Using the Dynamic Cache Probation Policy - cache after 2 accesses AND with a blob increment of 102400.
15:57:54,847 [ dlwsawcm36532] (e.VirtualRuleTableDispatchImpl) INFO - mFUAReusableEnabled = true, mFUAReusableEnabledStream = true
15:57:54,984 [ dlwsawcm36532] (pcentric.RACacheAppCentricImpl) INFO - Prune threshold is 10000
15:57:54,984 [ dlwsawcm36532] (pcentric.RACacheAppCentricImpl) INFO - mFUAReusableEnabled = true, mConstructorReuseEnabled = false, mFUAReusableEnabledStream = true
15:57:55,039 [ dlwsawcm36532] (pcentric.RACacheAppCentricImpl) INFO - Using RACacheAppCentricImpl for assembly cache implementations
15:57:55,039 [ dlwsawcm36532] (pcentric.RACacheAppCentricImpl) INFO - Assembly avoidance will use branch ruleset optimization
15:57:55,039 [ dlwsawcm36532] (nal.cache.AssemblyCacheWrapper) INFO - Assembly Cache Wrapper: configuredCacheType = AC
15:57:55,149 [ dlwsawcm36532] ( internal.mgmt.PRRequestorImpl) INFO - RecordWorkInProgress is not enabled
15:57:55,356 [ dlwsawcm36532] (orization.SessionAuthorization) INFO - RSL Update Behavior: Eager
15:57:55,462 [ dlwsawcm36532] ( internal.access.DatabaseImpl) INFO - Bytes input per interaction warning threshold: 50M
15:57:55,463 [ dlwsawcm36532] ( internal.access.DatabaseImpl) INFO - Database product: Oracle
15:57:55,463 [ dlwsawcm36532] ( internal.access.DatabaseImpl) INFO - Database version: Oracle Database 12c Enterprise Edition Release Proprietary information hidden.0 - 64bit Production
With the Partitioning, OLAP, Advanced Analytics and Real Application Testing options
15:57:55,463 [ dlwsawcm36532] ( internal.access.DatabaseImpl) INFO - Driver: Oracle JDBC driver
15:57:55,463 [ dlwsawcm36532] ( internal.access.DatabaseImpl) INFO - Driver version: Proprietary information hidden.0
15:57:55,468 [ dlwsawcm36532] (ternal.dictionary.ClassMapImpl) INFO - ClassMap using multi-tenant environment: false
15:57:55,468 [ dlwsawcm36532] (ternal.dictionary.ClassMapImpl) INFO - Reading the class group definitions
15:57:55,535 [ dlwsawcm36532] (ternal.dictionary.ClassMapImpl) INFO - Read 29 class group definitions
15:57:55,536 [ dlwsawcm36532] (ternal.dictionary.ClassMapImpl) INFO - Reading the class definitions
15:58:01,099 [ dlwsawcm36532] (ternal.dictionary.ClassMapImpl) INFO - Read 6843 class definitions
15:58:05,867 [ dlwsawcm36532] (al.access.InstanceExistsFilter) INFO - Scanning instance ids
15:58:12,597 [ dlwsawcm36532] (al.access.InstanceExistsFilter) INFO - Added 160677 entries to the instance exists filter in 6.730000 seconds with a false positive rate of 0.001
15:58:14,695 [ dlwsawcm36532] (.DeclarativePageDefinitionImpl) ERROR - Error occured while preloading declare pages
java.lang.ArrayIndexOutOfBoundsException: -1
at com.pega.pegarules.exec.internal.declare.infengine.cbi.GlobalDeclarativeClass.populateRuleProps(GlobalDeclarativeClass.java:664)
at com.pega.pegarules.exec.internal.declare.infengine.cbi.GlobalDeclarativeClass.listChangeDefinitions(GlobalDeclarativeClass.java:582)
at com.pega.pegarules.exec.internal.declare.infengine.cbi.GlobalDeclarativeClass.<init>(GlobalDeclarativeClass.java:412)
at com.pega.pegarules.exec.internal.declare.infengine.cbi.GlobalCache.getGlobalClass(GlobalCache.java:479)
at com.pega.pegarules.exec.internal.declare.infengine.cbi.DeclarativeCacheManagerImpl.getGlobalClass(DeclarativeCacheManagerImpl.java:1588)
at com.pega.pegarules.exec.internal.declare.infengine.cbi.RuntimeDeclarativeClass.<init>(RuntimeDeclarativeClass.java:133)
at com.pega.pegarules.exec.internal.declare.infengine.cbi.RuntimeCacheImpl.getRuntimeClass(RuntimeCacheImpl.java:308)
at com.pega.pegarules.exec.internal.declare.infengine.cbi.DeclarativeCacheManagerImpl.getRuntimeClass(DeclarativeCacheManagerImpl.java:1430)
at com.pega.pegarules.exec.internal.declare.infengine.cbi.ProcessingSupportImpl.getPropertyCandidates(ProcessingSupportImpl.java:108)
at com.pega.pegarules.exec.internal.declare.infengine.cbi.ProcessingSupportImpl.getAutoChainCandidates(ProcessingSupportImpl.java:165)
at com.pega.pegarules.data.internal.clipboard.DeclarativeSupportImpl.getAutoChainCandidates(DeclarativeSupportImpl.java:295)
at com.pega.pegarules.data.internal.clipboard.ClipboardPropertyImpl.autoChain(ClipboardPropertyImpl.java:1017)
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.getStringAndChain(ClipboardPageImpl.java:1590)
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.getString(ClipboardPageImpl.java:1169)
at com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.getString(ClipboardPageImpl.java:1157)
at com.pega.pegarules.exec.internal.declare.infengine.pages.DeclarativePageDefinitionCacheImpl.initialize(DeclarativePageDefinitionCacheImpl.java:291)
at com.pega.pegarules.session.internal.mgmt.PRNodeImpl.initializeSystem(PRNodeImpl.java:786)
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:373)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.getThreadAndInitialize(PRSessionProviderImpl.java:1913)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineStartup.initEngine(EngineStartup.java:640)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._initEngine_privact(EngineImpl.java:165)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.doStartup(EngineImpl.java:138)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener._contextInitialized_privact(WebAppLifeCycleListener.java:266)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener.contextInitialized(WebAppLifeCycleListener.java:174)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:419)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:460)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:509)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:5118)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5634)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:145)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:899)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:875)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:652)
at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:679)
at org.apache.catalina.startup.HostConfig$DeployDescriptor.run(HostConfig.java:1966)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)
15:58:14,886 [ dlwsawcm36532] ( etier.impl.EngineStartup) ERROR - PegaRULES initialization failed. Server: dlwsawcm36532
com.pega.pegarules.pub.context.InitializationFailedError: PRNodeImpl init failed
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:384)
Caused by: java.lang.ArrayIndexOutOfBoundsException: -1
at com.pega.pegarules.exec.internal.declare.infengine.cbi.RuntimeDeclarativeClassCore.resolveRules(RuntimeDeclarativeClassCore.java:398)
at com.pega.pegarules.exec.internal.declare.infengine.cbi.RuntimeDeclarativeClassCore.<init>(RuntimeDeclarativeClassCore.java:354)
at com.pega.pegarules.exec.internal.declare.infengine.cbi.RuntimeDeclarativeClass.<init>(RuntimeDeclarativeClass.java:134)
at com.pega.pegarules.exec.internal.basic.SystemSettingsImpl.getDynamic(SystemSettingsImpl.java:217)
at com.pega.pegarules.exec.internal.basic.SystemSettingsImpl.getDynamic(SystemSettingsImpl.java:191)
at com.pega.pegarules.data.internal.clipboard.DeclarativePageInstanceContainerImpl.<init>(DeclarativePageInstanceContainerImpl.java:68)
at com.pega.pegarules.data.internal.PRDataProviderImpl.getDeclarativePageInstanceContainer(PRDataProviderImpl.java:975)
at com.pega.pegarules.session.internal.mgmt.base.ThreadData.initNewInstance(ThreadData.java:441)
at com.pega.pegarules.session.internal.mgmt.PRThreadBase.<init>(PRThreadBase.java:146)
at com.pega.pegarules.session.internal.mgmt.PRThreadFactory.newProduct(PRThreadFactory.java:63)
at com.pega.pegarules.priv.factory.AbstractObjectFactory.acquireNewProduct(AbstractObjectFactory.java:290)
at com.pega.pegarules.priv.factory.AbstractObjectFactory.acquireObject(AbstractObjectFactory.java:366)
at com.pega.pegarules.session.internal.mgmt.PRThreadFactory.acquire(PRThreadFactory.java:55)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.<init>(PRThreadImpl.java:155)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.acquire(PRThreadImpl.java:172)
at com.pega.pegarules.session.internal.mgmt.base.RequestorThreadSync.getOrCreateThread(RequestorThreadSync.java:174)
at com.pega.pegarules.session.internal.mgmt.base.RequestorThreadSync.getOrCreateThread(RequestorThreadSync.java:161)
at com.pega.pegarules.session.internal.mgmt.base.RequestorThreadSync.getOrCreateThread(RequestorThreadSync.java:157)
at com.pega.pegarules.session.internal.mgmt.PRRequestorImpl.getOrCreateThread(PRRequestorImpl.java:715)
at com.pega.pegarules.session.internal.mgmt.PRNodeImpl.initializeSystem(PRNodeImpl.java:789)
... 27 more
15:58:14,886 [ dlwsawcm36532] ( etier.impl.EngineStartup) INFO - PegaRULES initialization failed. Server: dlwsawcm36532
15:58:14,914 [ dlwsawcm36532] (ervlet.WebAppLifeCycleListener) ERROR - Enterprise tier failed to initialize properly, PegaRULES not available
15:58:14,924 [ dlwsawcm36532] (ervlet.WebAppLifeCycleListener) INFO - Web Tier initialization is complete.
Show Less
