Virtusa
Last activity: 5 Dec 2016 9:56 EST
prpc.vmx file not available
I have downloaded the file DSME715_SS_PVS_20150224.zip and extracted it using 7-zip but there is no prpc.vmx file present in it. Also there are no sub folders of 'Application' or 'server' as mentioned in the PVS quick start guide. I see total of 64 files present in the 'Pega Decision Management Essentials' folder. The size of this folder is 13.33 GB for 64 files.
Let me know how to proceed.
Mohit,
Thanks a lot for your post.
This weekend we released the new version of the Pega Marketing Consultant learning path that is based upon Pega Marketing v7.13
Hence my recommendation is you enroll into this course instead and use the new Exercise System that is based upon VirtualBox.
Pega Marketing Consultant learning path:
Pega Decision Management Essentials (7.13) course – 2 days
Pega Marketing Essentials (7.13) course – 3 days
CPMC Practice Exam (7.13) – 2 hours
- Certified Pega Marketing Consultant exam – 90 minutes
Marco.
Updated: 19 Mar 2016 8:16 EDT
Virtusa
Thanks Marco. I was able to download the file and launch the URL. I am going through the lessons for PEGA DECISION MANAGEMENT ESSENTIALS (7.13) but not able to hear any audio in the videos being played in each lesson. There are only sub-titles present as the video plays. Let me know if thats how it is designed or I am missing anything?
Merkle Inc
ES
I tried to download and that works, but i cant lauch the virtual machine. An error message that file is corrupt. I uncompress with 7z
Elena,
It would be great if you can elaborate a bit on the steps you took and the part that does not work as expected.
Marco.
Merkle Inc
ES
Hello Marco.
I click to download, The message that expires in 10 seconds appears and I use the right click to save target as..
When is downloaded, I use 7z to uncompress, but a warning error appears regarding it can not open the file.
If i do, I try to open with VMware, and then appears the messages like is a corrupt file.
I cant use it
Elena,
To make sure we are helping you the right way, which of the following two are you going for?
- "Pega Decision Management Essentials (7.1)" with exercise system "DSME715_SS_PVS_20150224.zip"
- "Pega Decision Management Essentials (7.13)" with exercise system "marketing_713ml9_pvs_20151201.zip"
In addition what kind of laptop do you have?
- Windows OS
- Apple OS X
Marco.
Merkle Inc
ES
Windows OS
Elena,
It sounds like the archive got corrupted during the downloaded.
You can very easily verify this by testing the archive. See the two screenshots below.
If the test fails, you need to download the archive once more.
Marco.
Merkle Inc
ES
Hey,
That is the screen when Im testing, its the warning again. I download many time the file with explorer and Firefox and always is the same. What can I do?
https://drive.google.com/file/d/0B11N_DSKJNtuNmw0VXBIRXEzeE0/view?usp=sharing
Merkle Inc
ES
Its done,
This virtual machine only works with virtualbox
Elena,
I'm glad you successfully downloaded and extracted the Exercise System.
Yes, correct. We converted all Exercise Systems from VMware to VirtualBox.
Marco.
Merkle Inc
ES
I told its done, but i installed the Virtual Box, and launch the machine, but the page cant be displayed
Updated: 9 Mar 2016 10:45 EST
Elena,
So you are getting the following screen? (see below)
Please give the system 5 minutes to start up. (Sometimes it takes a bit longer depending on your laptop configuration.)
After that try the following URL: http://prpc.local:8080/
If the page is still not displayed, you can sign on as "architect" with password "password". This triggers a self diagnostic script. After 30 seconds please can try the URL again.
Marco.
Chauhan
Hi Marco,
I get this error when I try to open the VM:
File not found: prpc-cl5.vmdk
I have downloaded the ZIP 2-3 times but I keep getting the same error.
Zip is this - DSME715_SS_PVS_20150224
Any pointers?
NAB
Hi Sameer,
Just wondering as to how your issue around the missing 'prpc-cl5.vmdk' file was resolved. I am getting the exact same error and I am unable to launch the VM itself using VMWare player
Sameer,
Please be aware that:
- "Pega Decision Management Essentials (7.1)" requires exercise system "DSME715_SS_PVS_20150224.zip"
- "Pega Decision Management Essentials (7.13)" requires exercise system "marketing_713ml9_pvs_20151201.zip"
If you just started the course it is recommended you take v7.13
Marco.
Chauhan
Thanks Marco. I understand your point. I am keen on V7.13 but I am not sure if I can use the same Credit-Key to enroll for V7.13 as the one I used for V7.1?
Virtusa
With one exception(Improving Customer Experience with Next-Best-Action - one video) all the videos are sub-titles only.
Paul
Capgemini India Pvt Ltd
Failed to open a session for the virtual machine Pega Marketing Enablement 7.13 ML9.
VT-x is disabled in the BIOS for all CPU modes (VERR_VMX_MSR_ALL_VMX_DISABLED).
| Result Code: | E_FAIL (0x80004005) |
| Component: | ConsoleWrap |
| Interface: | IConsole {872da645-4a9b-1727-bee2-5585105b9eed} |
This is a BIOS setting which has to be enabled. It is dependent on the PC you use and I suggest you simply enter the VT-x enabled followed by your PC make and model into Google.
Paul
Areteans
Hi ,
I downloaded the PVS (lp7_71ml2_pvs_013014)from the course "LEVERAGING PEGA 7 (7.1)".
It doesn't contain any VBOX file, which it is supposed to have as per the quick start guide.
Please guide.
Regards
Amartya
