Importing Customer Service framework (7.1.4 version) failed after PRPC 7.1.9 upgrade
There is an application in PRPC v6.3 SP1 built on CPM 6.3 framework. After upgrading the application to PRPC v7.1.9, we tried to import Customer Service v7.1.4 framework. But import did not initialize with the below error being thrown:
2016-02-10 04:58:41,940 [ PegaRULES-Batch-2] [ STANDARD] [
] [ PegaRULES:07.10] ( internal.util.MoveLog) INFO Administrator@
pega.com - Error: Import failed due to an unallowed change (Column type)
2016-02-10 04:58:41,947 [ PegaRULES-Batch-2] [ STANDARD] [
] [ PegaRULES:07.10] (rnal.archive.ApplicationBundle) ERROR Administrator@
pega.com - The following SQL Statement contains a change to a column type. Type
Change Not allowed
pega.com - ALTER TABLE RULES.pca_rule_dialog ALTER COLUMN pyAccessibilityLevel I
NT
When we logged into the database directly, using the admin ID, we were able to alter the column.
So we are unable to import the CS v7.1.4 framework due to the mentioned issue. If you could please assist.
