Error while generating bix_keyring file
We are in the process of upgrading BIX 2.3 to BIX 7.1. We imported all the files and setup our config files as per the direction provided. When we are trying to generate a keyring for the bix we are getting below error:
D:\bix>bix_keyring.bat -Dpegarules.config=.\config\prconfig.xml -Dpegarules.logg
ing.configuration=.\config\prologging.xml com.pega.pegarules.exec.internal.util.
crypto.KeyringImpl .\config\priconfig.xml D:\BIX Buildfile: D:\bix\bix_keyring.
xml
Buildfile: d:\bix\bix_keyring.xml
Bix:
[echo] Performing Keyring
[java] Current "user.dir" (default directory) is: d:\bix
[java] Found spec for PegaRULES logging configuration using System property
: config/prlogging.xml
[java] Located PegaRULES logging configuration: jar:file:/D:/bix/lib/pega/p
rresources.jar!/prlogging.xml
[java] Found spec for PegaRULES (V5.x) configuration using System property:
config/prconfig.xml
[java] Located PegaRULES (V5.x) configuration: jar:file:/D:/bix/lib/pega/pr
resources.jar!/prconfig.xml
[java] 2016-02-03 14:43:55,457 [ main] [ ] [
] (b.StringBufferFactoryConstants) INFO - Running with $Id: Stri
ngBufferFactoryConstants.java,v 1.2 2008/04/07 18:08:00 clinb Exp $
73n62e37v11h82
[java] Enter update password: Incorrect password supplied, update not permi
tted
BUILD FAILED
d:\bix\bix_keyring.xml:17: Java returned: 1
Total time: 5 seconds
Firstly the build is failing and secondly I could see that BIX is still refering 5.x version
config/prconfig.xml
Can anyone please suggest what has to be modify.
Also do we need to modify the prbootstrap and ant file during this upgrade.
