Mercedes Benz Mobility
DE
Last activity: 14 Jul 2016 1:22 EDT
IllegalStateException during agent run
Work object creation is done through agent and following logs are captured, Can someone explain the probable cause for the exception,
18:38:40,593 [j2ee14_ws,maxpri=10]] (internal.database.ReporterImpl) FATAL - Trying to pop a database reporting element that is not at the top of the stack
java.lang.IllegalStateException: Trying to pop a database reporting element from com.pega.pegarules.monitor.internal.database.ReporterStackImpl@c924c319 that is not at the top of the stack
at com.pega.pegarules.monitor.internal.database.ReporterStackImpl.pop(ReporterStackImpl.java:129)
at com.pega.pegarules.data.internal.access.DatabaseImpl.executeRDB(DatabaseImpl.java:6520)
at com.pega.pegarules.data.internal.access.DatabaseImpl.executeRDB(DatabaseImpl.java:6444)
at com.pega.pegarules.data.internal.access.DatabaseImpl.executeRDB(DatabaseImpl.java:6425)
at com.pegarules.generated.activity.ra_action_pzgetchildkeys_7d8e45a331a4ee7df7afbcd389722685.step1_circum0(ra_action_pzgetchildkeys_7d8e45a331a4ee7df7afbcd389722685.java:251)
at com.pegarules.generated.activity.ra_action_pzgetchildkeys_7d8e45a331a4ee7df7afbcd389722685.perform(ra_action_pzgetchildkeys_7d8e45a331a4ee7df7afbcd389722685.java:72)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3099)
at com.pegarules.generated.activity.ra_action_pyloadmycasesnested_423ea85cce92981cdc7829650bdb071c.step3_circum0(ra_action_pyloadmycasesnested_423ea85cce92981cdc7829650bdb071c.java:400)
at com.pegarules.generated.activity.ra_action_pyloadmycasesnested_423ea85cce92981cdc7829650bdb071c.perform(ra_action_pyloadmycasesnested_423ea85cce92981cdc7829650bdb071c.java:106)
at com.pegarules.generated.activity.ra_action_pypopulatenestedcases_85f139292bfa70b7bc29f1e47d0cbb55.step2_circum0(ra_action_pypopulatenestedcases_85f139292bfa70b7bc29f1e47d0cbb55.java:252)
at com.pegarules.generated.activity.ra_action_pypopulatenestedcases_85f139292bfa70b7bc29f1e47d0cbb55.perform(ra_action_pypopulatenestedcases_85f139292bfa70b7bc29f1e47d0cbb55.java:89)
at com.pegarules.generated.activity.ra_action_pypopulatecasecontents_7691e23989ef53a9066daa4c083ab355.step11_circum0(ra_action_pypopulatecasecontents_7691e23989ef53a9066daa4c083ab355.java:1216)
at com.pegarules.generated.activity.ra_action_pypopulatecasecontents_7691e23989ef53a9066daa4c083ab355.perform(ra_action_pypopulatecasecontents_7691e23989ef53a9066daa4c083ab355.java:298)
at com.pegarules.generated.activity.ra_action_pypopulatecasecontentswrapper_f954dde97b1c2b500fdcd7a53ad97bc9.step3_circum0(ra_action_pypopulatecasecontentswrapper_f954dde97b1c2b500fdcd7a53ad97bc9.java:410)
at com.pegarules.generated.activity.ra_action_pypopulatecasecontentswrapper_f954dde97b1c2b500fdcd7a53ad97bc9.perform(ra_action_pypopulatecasecontentswrapper_f954dde97b1c2b500fdcd7a53ad97bc9.java:112)
at com.pegarules.generated.callActivity_060301_7PmEDUot9ka_dsT3VfbNbw.callActivity06_03_01(callActivity_060301_7PmEDUot9ka_dsT3VfbNbw.java:122)
at com.pegarules.generated.callActivity_060301_7PmEDUot9ka_dsT3VfbNbw.invoke(callActivity_060301_7PmEDUot9ka_dsT3VfbNbw.java:82)
at com.pega.pegarules.generation.internal.library.LibraryRuntime.resolveAndinvokeFunctionViaReflection(LibraryRuntime.java:132)
at com.pega.pegarules.generation.internal.library.LibraryRuntime.invokeLibraryRuntime(LibraryRuntime.java:109)
at com.pega.pegarules.session.internal.mgmt.Executable.invokeLibraryRuntime(Executable.java:8080)
at com.pega.pegarules.priv.generator.LibrarySupport.resolveAndInvokeFunctionViaReflection(LibrarySupport.java:181)
at com.pegarules.generated.pega_rules_utilities.callActivity(pega_rules_utilities.java:1251)
at com.pegarules.generated.flowaction.ra_action_pyassignmentlistgadget_90dd801265c5f07968088f727ea551d3.RunFlowActionActivity_circum0(ra_action_pyassignmentlistgadget_90dd801265c5f07968088f727ea551d3.java:378)
at com.pegarules.generated.flowaction.ra_action_pyassignmentlistgadget_90dd801265c5f07968088f727ea551d3.perform(ra_action_pyassignmentlistgadget_90dd801265c5f07968088f727ea551d3.java:72)
at com.pega.pegarules.session.internal.mgmt.Executable.doAction(Executable.java:2900)
at com.pegarules.generated.activity.ra_action_pzlocalactionrender_c2ab8f193464f1291fc1cd489fdd4ceb.step3_circum0(ra_action_pzlocalactionrender_c2ab8f193464f1291fc1cd489fdd4ceb.java:326)
at com.pegarules.generated.activity.ra_action_pzlocalactionrender_c2ab8f193464f1291fc1cd489fdd4ceb.perform(ra_action_pzlocalactionrender_c2ab8f193464f1291fc1cd489fdd4ceb.java:109)
at com.pegarules.generated.html_section.ra_stream_pzlocalactionimpl_8cafeeb5b37fc9b18d9077d6fc49b9a7.execute(ra_stream_pzlocalactionimpl_8cafeeb5b37fc9b18d9077d6fc49b9a7.java:153)
at com.pega.pegarules.session.internal.mgmt.Executable.getStream(Executable.java:3607)
at com.pega.pegarules.session.internal.mgmt.autostreams.AutoStreamRuleRuntime.getSectionStream(AutoStreamRuleRuntime.java:129)
at com.pegarules.generated.html_section.ra_stream_pxlocalaction_21ffbc11d79d7f2e60c20c672aa31a5d.execute(ra_stream_pxlocalaction_21ffbc11d79d7f2e60c20c672aa31a5d.java:132)
at com.pegarules.generated.html_section.ra_stream_pyassignmentlist_09136e900bca96713216c49fe6f5385b.execute(ra_stream_pyassignmentlist_09136e900bca96713216c49fe6f5385b.java:132)
at com.pegarules.generated.html_section.ra_stream_pyworkbodyleft_3dedbcb99077f53c5dcc435111021602.execute(ra_stream_pyworkbodyleft_3dedbcb99077f53c5dcc435111021602.java:199)
at com.pega.pegarules.session.internal.mgmt.StreamBuilderTools.appendStreamKeepProperties(StreamBuilderTools.java:712)
at com.pega.pegarules.session.internal.mgmt.autostreams.IncludeStreamRuntime.getStream(IncludeStreamRuntime.java:328)
at com.pega.pegarules.session.internal.mgmt.autostreams.IncludeStreamRuntime.emitIncludeStreamReference(IncludeStreamRuntime.java:250)
at com.pega.pegarules.session.internal.mgmt.autostreams.AutoStreamRuntimeImpl.emitIncludeStreamReference(AutoStreamRuntimeImpl.java:253)
at com.pega.pegarules.jsptags.IncludeTag.doEndTag(IncludeTag.java:460)
at com.pegarules.generated.html_section.ra_stream_pyworkbody_3b08c9d94571f988a0e96fb5e735c4a8.execute(ra_stream_pyworkbody_3b08c9d94571f988a0e96fb5e735c4a8.java:168)
at com.pegarules.generated.html_section.ra_stream_pyworkcontainer_ea635c6a0c76feb4f910fdbb25f6f9a2.execute(ra_stream_pyworkcontainer_ea635c6a0c76feb4f910fdbb25f6f9a2.java:160)
at com.pegarules.generated.html_harness.ra_stream_confirm_3139b0987bdc0b2756648550ad1ebf7e.execute(ra_stream_confirm_3139b0987bdc0b2756648550ad1ebf7e.java:275)
at com.pega.pegarules.session.internal.mgmt.Executable.getStream(Executable.java:3468)
at com.pegarules.generated.activity.ra_action_show_harness_94eeb9db7b55e692da7ab10f90ea5e77.step6_circum0(ra_action_show_harness_94eeb9db7b55e692da7ab10f90ea5e77.java:745)
at com.pegarules.generated.activity.ra_action_show_harness_94eeb9db7b55e692da7ab10f90ea5e77.perform(ra_action_show_harness_94eeb9db7b55e692da7ab10f90ea5e77.java:158)
at com.pegarules.generated.activity.ra_action_add_0e677130cc23e69bc7c09712b58a5964.step11_circum0(ra_action_add_0e677130cc23e69bc7c09712b58a5964.java:1207)
at com.pegarules.generated.activity.ra_action_add_0e677130cc23e69bc7c09712b58a5964.perform(ra_action_add_0e677130cc23e69bc7c09712b58a5964.java:249)
