Issue while upgrading from PRPC6.3 to PRPC7.1.8
We are upgrading our PRPC6.3 single schema environment to PRPC718 split schema. Steps we followed
1. We created one schema PRPCRULESTEMP71
2. Migrated rules from current 6.3 schema (PRPC63) to the temorary schema PRPCRULESTEMP71. It worked fine. No issue.
3. While running the rules upgrade on PRPCRULESTEMP71 we are getting the below error. Please find below the parameters for setupdatabase.proreties files also.
Setupdatabase.properties:
pega.jdbc.driver.jar=/data01/app/oracle/product/11.2.0/db_1/jdbc/lib/ojdbc6.jar
pega.jdbc.driver.class=oracle.jdbc.OracleDriver
pega.database.type=oracledate
pega.jdbc.url=jdbc:oracle:thin:@10.167.203.18:1521/prpcdb
pega.jdbc.username=prpcadmin
pega.jdbc.password=xxxxx
rules.schema.name=prpcrulestemp71
data.schema.name=
user.temp.dir=/data01/software/PRPC718/UpgradeTempDir/temp
ERROR:
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
[java] at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85)
[java] Caused by: com.pega.pegarules.pub.context.InvalidConfigurationException: Data-Admin-Requestor instance "${current.system.name}!BATCH" not found
[java] From: (B8FEA8A8EF7412F434A8E08EEF8CBE3CD)
[java] at com.pega.pegarules.session.internal.authorization.SessionAuthorization.reset(SessionAuthorization.java:450)
[java] at com.pega.pegarules.session.internal.authorization.SessionAuthorization.<init>(SessionAuthorization.java:245)
[java] ... 58 more
[java]
[java] Exception in thread "PRPCUpgrade" java.lang.RuntimeException: Problem during method invocation (main)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:278)
[java] Caused by: com.pega.pegarules.pub.context.PRSecurityException: Unable to construct authorization core due to authorization failure
Please suggest.
