Problem in Exercise links -
I Have started PEGA 7.1 fundamentals course, and sometimes the link saying "open exercise" is not pointing to correct application.
For Example In "Working with Data Objects" Concept
1. In solution it says that we have to create DATA OBJECT TYPE with pattern class as MainCo.EmpReimb.data but the application does not have that class.
2. I tried to search for the class in serach bar also
3. Problem is It is showing "HRservices application" instead of "Employee Reimbursement application"
4. Because of this i coundn't complete the exercise properly
Are you following the lessons in order?
The Employee Reimbursements application is created in the Creating a New Pega 7 Application lesson. Then over the next couple of lessons, the case types are created and elaborated on.
Click on the HR Services app name in the header bar (to the right of the Pega 7 and Designer Studio icons), and hover over Switch Application. If you completed the previous exercises, you should see both the HR Services and Employee Reimbursements applications. Click on Employee Reimbursements to switch to that app.
If you do not see Employee Remibursements, then you must complete the previous exercises as noted.
eddie
