HCL
Last activity: 15 Apr 2015 13:54 EDT
Import issue with HRServices_Specifications.xlsx workbook
Chapter: Principles of Process Design
Exercise #2 (Overall Step#4 in chapter).
File provided for download: HRServices_Specifications.xlsx
Instruction for step:
Select Application > Profile from the Designer Studio menu and then select the
Specifications tab. Use the blue Actions drop-down menu to import the
HRServices_Specifications.xlsx file.
Issue Description:
Upon choosing provided file for upload and clicking the "Next" button, I am receiving an error to the effect of "File not recognized / Invalid format".
Is anyone else getting the same issue? Please advise.
Thank you all.
This file works, but please try downloading the file again. There may have been an issue during the download. If this doesn't work, please send an email to [email protected] and we will send you the file.
Bill
Scotiabank
We are also getting the same error.
Scotiabank
Please clear your cache and try to upload the file again.
Thank You,
Bill
Luxoft
RU
Hi!
After IE cache cleared, this error repeated.
If compare HRServices_Specifications.xlsx with template HRServices_UserStories.xlsx (get it when click "Download Template" on the same screen), we can see differences. Maybe this differences are the cause of this error.
We are use downloadable exercise sistem ащк BA course.
The work around for this is to access the Specification Tab and then download an Excel spreadsheet.
Actions>Export to Excel. Save this Spreadsheet somewhere (in my example I will call it Spreadsheet A). Open Spreadsheet A and copy the information from the spreadsheet downloaded from the training environment (which I will call Spreadsheet B) into the newly downloaded spreadsheet (Spreadsheet A). Now Spreadsheet A and Spreadsheet B will look similar. Save Spreadsheet A with the new information in it. Upload Spreadsheet A into your system. Actions>Import from Excel.
Luxoft
RU
2RATHW
Thanks.
I've done it before writing first post)
This work around doesnt work.
Best regards. volazulac.
What browser and version are you using?
What error message do you get when you try the work around?
Are you able to download the Excel spreadsheet? If not, what is the error message?
If you are able to download the spreadsheet, what error message do you get on the upload?
Bill Rathert
Luxoft
RU
Try IE 11, Chrome 41, FFox 37
Error message does not appear. Look at attached screen.
Step by step (template basic):
- Start IE11. Clear cach.
- Download HRServices_Specifications.xlsx right panel for first exersize topic Principles of Process Design;
- Download template HRServices_UserStories.xlsx from Case explorer -> Time Off (is name my case type) -> Action ->Import from Excel -> Download Template
- Change name HRServices_UserStories.xlsx to A.xlsx
- Copy one string with specification from HRServices_Specifications.xlsx to A.xlsx (as I wrote earlier - we have differents number and name colums between HRServices_UserStories.xlsx and A.xlsx ). my A.xlsx you can load from Gdrive (https://drive.google.com/file/d/0BxReg-M9qz6laGVMckxZZmU3VVE/view?usp=sharing)
- HRServices_UserStories.xlsx from Case explorer -> Time Off (is name my case type) -> Action ->Import from Excel click Browse and choose A.xlsx
- When click NEXT - red triangle icon appear with exclamation mark iside. Look attach (or link https://drive.google.com/file/d/0BxReg-M9qz6lQmFFd1VzOG5JcFU/view?pli=1).
Please mouse over the red arrow to show me the error message you are getting. Also, I do not see the file name listed in the import area. DId the name get removed when you clicked next?
Bill
Bill,
please don't be mad at me for stepping on this post, but this is a failure in the course materials.
There is a disconnect in Project Methodology between the spreadsheet made available for download (PegaBPM-based) and the HR Services app in the virtual machine we make available for download (Scrum-based).
The easiest fix for now is to change the project methodology in the HR Services Application Overivew.
On the header just to the left of the big Designer Studio, select HR Services > Open Overview
On the right side of the Application Overivew landing page is a section for Project Methodology
Click the Edit button and select PegaBPM from the list, then save your changes.
Now, go do the import exercise and it will work just fine.
eddie
Thanks. Eddie. I knew we had different spread sheets out there, but I sent both of those to Edison and that didn't work. All good now! I spoke to a few people and couldn't get any different solutions. Was going to email you next. Thank you.
Scotiabank
Thank you. That worked for me.
Good, I am happy to know it is working for you. Sorry about the botched exercise.
I am working on getting a usable spreadsheet posted to the download link.
eddie
