Problem with pljava installing Pega 7.1.7
i'm installing pega 7.1.7 i been having a lot of problem with pljava, at the end i coul solved, but now that all was installed , apache is working and all the war files were deployed. but when i try to access to prweb site i got the next messages:
============ PegaRULES Bootstrap Configuration ============
Date: Thu Mar 12 08:00:34 CST 2015
Java Version: Oracle Corporation 1.7.0_55
Configuration: file:/var/lib/tomcat7/webapps/prweb/WEB-INF/classes/prbootstrap.properties
Pega-EngineCode: 07-10-15
ASM Version: -1239066975
Database: PostgreSQL 9.1.15
Driver: PostgreSQL Native Driver PostgreSQL 9.1 JDBC4 (build 903)
Active CodeSets: pega-enginecode:07-10-15 at (latest patch)
customer:06-01-01 at (latest patch)
=============== End Bootstrap Configuration ===============
Current "user.dir" (default directory) is: /var/lib/tomcat7
Located PegaRULES logging configuration: file:/var/lib/tomcat7/webapps/prweb/WEB-INF/classes/prlogging.xml
2015-03-12 08:00:34,854 [ocalhost-startStop-1] [ ] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - System Start Date: Thu Mar 12 08:00:34 CST 2015
2015-03-12 08:00:34,861 [ocalhost-startStop-1] [ ] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - PegaRULES Web Tier 7.10 (ML7)
2015-03-12 08:00:34,861 [ocalhost-startStop-1] [ ] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - coreAssemblyCached_717_644: 2014-11-26 14.24 EST
2015-03-12 08:00:34,862 [ocalhost-startStop-1] [ ] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - http://camscm/svn/PRPC_core/branches/integration/717/dev/core (114577)
2015-03-12 08:00:34,862 [ocalhost-startStop-1] [ ] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - Now starting the PegaRULES Web Tier...
2015-03-12 08:00:34,892 [ocalhost-startStop-1] [ ] [ ] [ ] ( context.web.WebEnvironment) INFO - Web tier using local JNDI context
factory = org.apache.naming.java.javaURLContextFactory
url = <not specified>
path = java:
2015-03-12 08:00:34,892 [ocalhost-startStop-1] [ ] [ ] [ ] ( priv.context.JNDIEnvironment) INFO - Web-tier default Engine bean name is EngineBMT
Located PegaRULES (V5.x) configuration: file:/var/lib/tomcat7/webapps/prweb/WEB-INF/classes/prconfig.xml
Mar 12, 2015 8:00:35 AM com.pega.pegarules.internal.bootstrap.SettingReaderJNDI
19830421:
19830421:
2015-03-12 08:00:35,400 [ocalhost-startStop-1] [ ] [ ] [ ] ( basic.config.SettingsImpl) INFO - prconfig.xml merged with prconfig entries in Data-Admin-System-Settings
2015-03-12 08:00:35,575 [ocalhost-startStop-1] [ ] [ ] [ ] (able.DefaultVirtualTableConfig) INFO - Using Hybrid Virtual Rules Table implementation
2015-03-12 08:00:35,575 [ocalhost-startStop-1] [ ] [ ] [ ] (able.DefaultVirtualTableConfig) INFO - VTable dispatches rules for 7 Aspects: 'Validate, Model, Collection, Input, Action, When, Alias'.
2015-03-12 08:00:35,575 [ocalhost-startStop-1] [ ] [ ] [ ] (able.DefaultVirtualTableConfig) INFO - ABA[AC] dispatches rules for 1 Aspect: 'Stream'.
2015-03-12 08:00:35,577 [ocalhost-startStop-1] [ ] [ ] [ ] ( priv.context.JNDIEnvironment) INFO - Enterprise-tier default Engine bean name is EngineBMT
2015-03-12 08:00:35,578 [ocalhost-startStop-1] [ ] [ ] [ ] (r.context.EtierEnvironmentImpl) INFO - Enterprise tier using local JNDI context
path = java:
2015-03-12 08:00:35,685 [ocalhost-startStop-1] [ ] [ ] [ ] (ion.internal.PRGenProviderImpl) INFO - invokeDynamic instrumentation for inlining is enabled
2015-03-12 08:00:35,686 [ocalhost-startStop-1] [ ] [ ] [ ] (ion.internal.PRGenProviderImpl) INFO - Assembly Version: -1239066975
2015-03-12 08:00:36,129 [ocalhost-startStop-1] [ ] [ ] [ ] ( internal.archive.ParUtilsImpl) INFO - Setting archive staging directory: /PEGA/PEGA_TEMP/RuleMgmt
2015-03-12 08:00:36,129 [ocalhost-startStop-1] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - JVM Information:
2015-03-12 08:00:36,129 [ocalhost-startStop-1] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Vendor: Oracle Corporation, JVM version: 1.7.0_55
2015-03-12 08:00:36,130 [ocalhost-startStop-1] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - VM Name: OpenJDK 64-Bit Server VM(build 1.7.0_55-b14)
2015-03-12 08:00:36,130 [ocalhost-startStop-1] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Host OS Information:
2015-03-12 08:00:36,130 [ocalhost-startStop-1] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - OS: Linux, version: 3.13.0-32-generic
2015-03-12 08:00:36,130 [ocalhost-startStop-1] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Architecture: amd64
2015-03-12 08:00:36,130 [ocalhost-startStop-1] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - PegaRULES Enterprise Tier 7.10 (ML7)
2015-03-12 08:00:36,130 [ocalhost-startStop-1] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - coreAssemblyCached_717_644: 2014-11-26 14.24 EST
2015-03-12 08:00:36,131 [ocalhost-startStop-1] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Deployed in web tier only
2015-03-12 08:00:36,131 [ocalhost-startStop-1] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Servlet container: Tomcat
2015-03-12 08:00:36,131 [ocalhost-startStop-1] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web server: Apache Tomcat/7.0.52 (Ubuntu)
2015-03-12 08:00:36,131 [ocalhost-startStop-1] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web server environment: Tomcat
2015-03-12 08:00:36,131 [ocalhost-startStop-1] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web-tier default Engine bean name: EngineBMT
2015-03-12 08:00:36,131 [ocalhost-startStop-1] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Web to Enterprise tier delegate type: pojo
2015-03-12 08:00:36,132 [ocalhost-startStop-1] [ ] [ ] [ ] ( etier.impl.EngineStartup) INFO - Now starting the PegaRULES Engine...
Unable to locate KeyringImpl keyring after trying:
<properties>
tomcat7-pegarules.keyring
sandbox-pegarules.keyring
pegarules.keyring
2015-03-12 08:00:36,187 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Base database information:
2015-03-12 08:00:36,187 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Database name: pegadata
2015-03-12 08:00:36,187 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Defined by: JNDI name
2015-03-12 08:00:36,187 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Data source name: java:comp/env/jdbc/PegaRULES
2015-03-12 08:00:36,188 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Minimum connection count: 0
2015-03-12 08:00:36,188 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Maximum connection count: unlimited
2015-03-12 08:00:36,188 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Failover database: none
2015-03-12 08:00:36,188 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Default Schema:data
2015-03-12 08:00:36,189 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Base database information:
2015-03-12 08:00:36,189 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Database name: pegarules
2015-03-12 08:00:36,189 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Defined by: JNDI name
2015-03-12 08:00:36,190 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Data source name: java:comp/env/jdbc/PegaRULES
2015-03-12 08:00:36,190 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Minimum connection count: 0
2015-03-12 08:00:36,190 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Maximum connection count: unlimited
2015-03-12 08:00:36,190 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Failover database: none
2015-03-12 08:00:36,190 [ocalhost-startStop-1] [ ] [ ] [ ] (l.access.ConnectionManagerImpl) INFO - Default Schema:rules
2015-03-12 08:00:36,339 [ocalhost-startStop-1] [ ] [ ] [ ] ( external.timers.CpuTimer) INFO - CPU timers set to TOTALSONLY. Use prconfig setting 'initialization/CpuTimerLevel' with one of [FULL, TOTALSONLY, NONE] to modify.
2015-03-12 08:00:36,342 [ocalhost-startStop-1] [ ] [ ] [ ] (.timers.EnvironmentDiagnostics) INFO - Using Java 1.5 Thread.getAllStackTraces() for thread dumps
Using sun.misc.Perf high-resolution timer for elapsed timings
Using Java 5 Management beans for thread CPU timings.
Using Java 5 Management beans for process CPU timings: 18700000000
2015-03-12 08:00:36,413 [ocalhost-startStop-1] [ ] [ ] [ ] (.access.PageDatabaseMapperImpl) INFO - DeflateStreams is turned ON.
2015-03-12 08:00:36,444 [ocalhost-startStop-1] [ ] [ ] [ ] (pboard.StorageStreamCommonImpl) INFO - engineCodeVersion: 07-10-15
2015-03-12 08:00:36,762 [ocalhost-startStop-1] [ ] [ ] [ ] ( internal.mgmt.PRNodeImpl) INFO - Using codeset version and timestamp map: {pega-enginecode=07-10-15@2015-03-11 11:18:00.0, customer=06-01-01@1969-12-31 18:00:00.0}
2015-03-12 08:00:36,917 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Generated source : file://runtime:/PRGenJava/
2015-03-12 08:00:36,917 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Generated classes: file://runtime:/PRGenClasses/
2015-03-12 08:00:36,918 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Web-tier real root path: /var/lib/tomcat7/webapps/prweb
2015-03-12 08:00:36,918 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Web-tier temporary path: /var/cache/tomcat7/Catalina/localhost/prweb
2015-03-12 08:00:36,918 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES real root path: /var/lib/tomcat7/webapps/prweb
2015-03-12 08:00:36,918 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES effective root path: file://default:/
2015-03-12 08:00:36,918 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - PegaRULES effective temp path: /PEGA/PEGA_TEMP
2015-03-12 08:00:36,918 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using genSourcePath: file://runtime:/PRGenJava/
2015-03-12 08:00:36,918 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using genClassPath (database): pegajdbc://1989710731:1/
2015-03-12 08:00:36,918 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using genClassPath (files): file://runtime:/PRGenClasses/
2015-03-12 08:00:36,918 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using external classes in: <not using external classes>
2015-03-12 08:00:36,918 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Using external jars in: <not using external jars>
2015-03-12 08:00:37,060 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - Servlet classes: /usr/share/java/servlet-api-3.0.jar (javax.servlet : 3.0.0.v201103241327)
2015-03-12 08:00:37,060 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - JSP classes: /usr/share/java/jsp-api-2.2.jar (javax.servlet.jsp : 2.2.0.v201103241327)
2015-03-12 08:00:37,060 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - EJB classes: (none)
2015-03-12 08:00:37,060 [ sandbox] [ ] [ ] [ ] (rnal.mgmt.InitialConfiguration) INFO - JMS classes: (none)
2015-03-12 08:00:37,325 [ sandbox] [ ] [ ] [ ] (rnal.access.CacheContainerImpl) INFO - Using the Dynamic Cache Probation Policy - cache after 2 accesses AND with a blob increment of 102400.
2015-03-12 08:00:37,496 [ sandbox] [ ] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - Prune threshold is 10000
2015-03-12 08:00:37,496 [ sandbox] [ ] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - mFUAReusableEnabled = true, mConstructorReuseEnabled = false, mFUAReusableEnabledStream = true
2015-03-12 08:00:37,542 [ sandbox] [ ] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - Using RACacheAppCentricImpl for assembly cache implementations
2015-03-12 08:00:37,542 [ sandbox] [ ] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - Assembly avoidance will use branch ruleset optimization
2015-03-12 08:00:37,542 [ sandbox] [ ] [ ] [ ] (nal.cache.AssemblyCacheWrapper) INFO - Assembly Cache Wrapper: configuredCacheType = AC
2015-03-12 08:00:37,637 [ sandbox] [ ] [ ] [ ] ( internal.mgmt.PRRequestorImpl) INFO - RecordWorkInProgress is not enabled
2015-03-12 08:00:37,844 [ sandbox] [ ] [ ] [ ] (orization.SessionAuthorization) INFO - RSL Update Behavior: Eager
2015-03-12 08:00:37,947 [ sandbox] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Bytes input per interaction warning threshold: 50M
2015-03-12 08:00:37,951 [ sandbox] [ ] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - ClassMap using multi-tenant environment: false
2015-03-12 08:00:37,952 [ sandbox] [ ] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - Reading the class group definitions
2015-03-12 08:00:38,006 [ sandbox] [ ] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - Read 14 class group definitions
2015-03-12 08:00:38,007 [ sandbox] [ ] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - Reading the class definitions
2015-03-12 08:00:42,454 [ sandbox] [ ] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - Read 3882 class definitions
2015-03-12 08:00:43,198 [ sandbox] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Database product: PostgreSQL
2015-03-12 08:00:43,198 [ sandbox] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Database version: 9.1.15
2015-03-12 08:00:43,198 [ sandbox] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Driver: PostgreSQL Native Driver
2015-03-12 08:00:43,198 [ sandbox] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Driver version: PostgreSQL 9.1 JDBC4 (build 903)
2015-03-12 08:00:43,198 [ sandbox] [ ] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Version of JDBC supported by driver: 4.0
2015-03-12 08:00:45,330 [ LOAD_INSTANCEFILTER] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - load instance filter ..starting
2015-03-12 08:00:45,335 [ LOAD_INSTANCEFILTER] [ STANDARD] [ ] [ ] (al.access.InstanceExistsFilter) INFO - Scanning instance ids
2015-03-12 08:00:45,330 [AD_DECLARATIVECOMMON] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - load getDeclarativeCommon ..starting
2015-03-12 08:00:45,331 [EPAGEDEFINITIONCACHE] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - load Declarative Page Definition Cache ..starting
2015-03-12 08:00:45,339 [AD_DECLARATIVECOMMON] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - load getDeclarativeCommon ..done
2015-03-12 08:00:48,305 [EPAGEDEFINITIONCACHE] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - load Declarative Page Definition Cache ..done
PRPC default rounding mode set to HALF_EVEN
2015-03-12 08:00:50,214 [ LOAD_INSTANCEFILTER] [ STANDARD] [ ] [ ] (al.access.InstanceExistsFilter) INFO - Added 88985 entries to the instance exists filter in 4.878000 seconds with a false positive rate of 0.001
2015-03-12 08:00:50,215 [ LOAD_INSTANCEFILTER] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - load instance filter ..done
2015-03-12 08:00:50,918 [ sandbox] [ STANDARD] [ ] [ ] ( internal.mgmt.PRNodeImpl) INFO - Node Identification: "sandbox PEGA7SANDBOX 2015-03-12 14:00:37.617 GMT"; Node Id: 7d38e8045aac015dba17400143f9aa51
Mar 12, 2015 8:00:51 AM com.hazelcast.instance.DefaultAddressPicker
INFO: Interfaces is disabled, trying to pick one address from TCP-IP config addresses: []
INFO: Prefer IPv4 stack is true.
WARNING: Could not find a matching address to start with! Picking one of non-loopback addresses.
INFO: Picked Address[ Proprietary information hidden]:5701, using socket ServerSocket[addr=/ Proprietary information hidden,localport=5701], bind any local is true
Mar 12, 2015 8:00:51 AM com.hazelcast.system
INFO: [ Proprietary information hidden]:5701 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Hazelcast Community Edition 3.2 (20140321) starting at Address[ Proprietary information hidden]:5701
INFO: [ Proprietary information hidden]:5701 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Copyright (C) 2008-2014 Hazelcast.com
Mar 12, 2015 8:00:51 AM com.hazelcast.instance.Node
INFO: [ Proprietary information hidden]:5701 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Creating TcpIpJoiner
Mar 12, 2015 8:00:51 AM com.hazelcast.core.LifecycleService
INFO: [ Proprietary information hidden]:5701 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Address[ Proprietary information hidden]:5701 is STARTING
Mar 12, 2015 8:00:51 AM com.hazelcast.cluster.TcpIpJoiner
Members [1] {
Member [ Proprietary information hidden]:5701 this
Mar 12, 2015 8:00:52 AM com.hazelcast.core.LifecycleService
INFO: [ Proprietary information hidden]:5701 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Address[ Proprietary information hidden]:5701 is STARTED
2015-03-12 08:00:52,133 [ sandbox] [ STANDARD] [ ] [ ] (nternal.PRClusterHazelcastImpl) INFO - First node in this Cluster is starting.
2015-03-12 08:00:52,134 [ sandbox] [ STANDARD] [ ] [ ] ( internal.mgmt.PRNodeImpl) INFO - Clustering technology: hazelcast
Mar 12, 2015 8:00:52 AM com.hazelcast.partition.InternalPartitionService
INFO: [ Proprietary information hidden]:5701 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Initializing cluster partition table first arrangement...
2015-03-12 08:01:02,256 [ sandbox] [ STANDARD] [ ] [ ] (.internal.PRSearchProviderImpl) INFO - Initialized full text search functionality for this node.
2015-03-12 08:01:02,280 [ sandbox] [ STANDARD] [ ] [ ] ( internal.mgmt.PRNodeImpl) INFO - Checking Cluster consistency
2015-03-12 08:01:02,293 [ sandbox] [ STANDARD] [ ] [ ] (nternal.PRClusterHazelcastImpl) INFO - This node is the only node in the cluster. Restarting cluster to check for new memberships before node initialization completes
Mar 12, 2015 8:01:02 AM com.hazelcast.instance.DefaultAddressPicker
INFO: Picked Address[ Proprietary information hidden]:5702, using socket ServerSocket[addr=/ Proprietary information hidden,localport=5702], bind any local is true
Mar 12, 2015 8:01:02 AM com.hazelcast.system
INFO: [ Proprietary information hidden]:5702 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Hazelcast Community Edition 3.2 (20140321) starting at Address[ Proprietary information hidden]:5702
INFO: [ Proprietary information hidden]:5702 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Copyright (C) 2008-2014 Hazelcast.com
Mar 12, 2015 8:01:02 AM com.hazelcast.instance.Node
INFO: [ Proprietary information hidden]:5702 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Creating TcpIpJoiner
Mar 12, 2015 8:01:02 AM com.hazelcast.core.LifecycleService
INFO: [ Proprietary information hidden]:5702 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Address[ Proprietary information hidden]:5702 is STARTING
Mar 12, 2015 8:01:02 AM com.hazelcast.cluster.TcpIpJoiner
Members [1] {
Member [ Proprietary information hidden]:5702 this
WARNING: [ Proprietary information hidden]:5702 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Config seed port is 5701 and cluster size is 1. Some of the ports seem occupied!
INFO: [ Proprietary information hidden]:5702 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Address[ Proprietary information hidden]:5702 is STARTED
2015-03-12 08:01:02,337 [ sandbox] [ STANDARD] [ ] [ ] (nternal.PRClusterHazelcastImpl) INFO - First node in this Cluster is starting.
2015-03-12 08:01:02,337 [ sandbox] [ STANDARD] [ ] [ ] (nternal.PRClusterHazelcastImpl) INFO - New instance started, shutting down original instance
INFO: [ Proprietary information hidden]:5701 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Address[ Proprietary information hidden]:5701 is SHUTTING_DOWN
Mar 12, 2015 8:01:02 AM com.hazelcast.initializer
INFO: [ Proprietary information hidden]:5701 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Destroying node initializer.
INFO: [ Proprietary information hidden]:5701 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Hazelcast Shutdown is completed in 59 ms.
INFO: [ Proprietary information hidden]:5701 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Address[ Proprietary information hidden]:5701 is SHUTDOWN
Mar 12, 2015 8:01:02 AM com.hazelcast.partition.InternalPartitionService
INFO: [ Proprietary information hidden]:5702 [962452fed6e1b28bcc4f6da4c5e659f0] [3.2] Initializing cluster partition table first arrangement...
2015-03-12 08:01:02,528 [ sandbox] [ STANDARD] [ ] [ ] ( internal.mgmt.PRNodeImpl) INFO - Preparing Rule-Utility-Library definitions for use...
com.pega.pegarules.pub.PRRuntimeException: Method Invocation exception
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1190)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:926)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:811)
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:378)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.getThreadAndInitialize(PRSessionProviderImpl.java:1905)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineStartup.initEngine(EngineStartup.java:657)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._initEngine_privact(EngineImpl.java:165)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.doStartup(EngineImpl.java:138)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener._contextInitialized_privact(WebAppLifeCycleListener.java:280)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener.contextInitialized(WebAppLifeCycleListener.java:187)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:338)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:379)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:216)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:265)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4973)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5467)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:901)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:877)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:632)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1073)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1857)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:744)
Caused by: java.lang.reflect.InvocationTargetException
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1188)
... 31 more
Caused by: java.lang.OutOfMemoryError: Java heap space
at java.lang.String.toCharArray(String.java:2753)
at com.pega.pegarules.generation.internal.library.LibraryFunctionUtilityImpl.compileLibraryAndFunctions(LibraryFunctionUtilityImpl.java:2660)
at com.pega.pegarules.generation.internal.library.LibraryFunctionUtilityImpl.generateLibrary(LibraryFunctionUtilityImpl.java:1067)
at com.pega.pegarules.generation.internal.library.LibraryFunctionUtilityImpl.extractAll(LibraryFunctionUtilityImpl.java:440)
at com.pega.pegarules.session.internal.mgmt.PRNodeImpl.handleExtraction(PRNodeImpl.java:1537)
at com.pega.pegarules.session.internal.mgmt.PREnvironment.finishInit(PREnvironment.java:504)
2015-03-12 08:01:53,796 [ sandbox] [ STANDARD] [ ] [ ] ( etier.impl.EngineStartup) ERROR - PegaRULES initialization failed. Server: sandbox
com.pega.pegarules.pub.context.InitializationFailedError: PRNodeImpl init failed
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:386)
Caused by: com.pega.pegarules.pub.PRRuntimeException: Method Invocation exception
... 28 more
... 31 more
2015-03-12 08:01:53,801 [ sandbox] [ STANDARD] [ ] [ ] ( etier.impl.EngineStartup) INFO - PegaRULES initialization failed. Server: sandbox
2015-03-12 08:01:53,847 [ sandbox] [ STANDARD] [ ] [ ] (ervlet.WebAppLifeCycleListener) ERROR - Enterprise tier failed to initialize properly, PegaRULES not available
2015-03-12 08:01:53,856 [ sandbox] [ STANDARD] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - Web Tier initialization is complete.
Mar 12, 2015 8:01:55 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive /var/lib/tomcat7/webapps/prsysmgmt.war
SMA: Using configuration file: /var/lib/tomcat7/work/Catalina/localhost/prsysmgmt/Nodes.xml
Mar 12, 2015 8:01:59 AM com.opensymphony.xwork2.config.providers.XmlConfigurationProvider info
INFO: Parsing configuration file [struts-default.xml]
INFO: Unable to locate configuration files of the name struts-plugin.xml, skipping
INFO: Parsing configuration file [struts-plugin.xml]
INFO: Parsing configuration file [struts.xml]
Mar 12, 2015 8:01:59 AM org.apache.struts2.config.AbstractBeanSelectionProvider info
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.ObjectFactory)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.factory.ActionFactory)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.factory.ResultFactory)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.factory.ConverterFactory)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.factory.InterceptorFactory)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.factory.ValidatorFactory)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.FileManagerFactory)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.conversion.impl.XWorkConverter)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.conversion.impl.CollectionConverter)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.conversion.impl.ArrayConverter)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.conversion.impl.DateConverter)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.conversion.impl.NumberConverter)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.conversion.impl.StringConverter)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.conversion.ConversionPropertiesProcessor)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.conversion.ConversionFileProcessor)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.conversion.ConversionAnnotationProcessor)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.conversion.TypeConverterCreator)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.conversion.TypeConverterHolder)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.TextProvider)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.LocaleProvider)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.ActionProxyFactory)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.conversion.ObjectTypeDeterminer)
INFO: Choosing bean (struts) for (org.apache.struts2.dispatcher.mapper.ActionMapper)
INFO: Choosing bean (jakarta) for (org.apache.struts2.dispatcher.multipart.MultiPartRequest)
INFO: Choosing bean (struts) for (org.apache.struts2.views.freemarker.FreemarkerManager)
INFO: Choosing bean (struts) for (org.apache.struts2.components.UrlRenderer)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.validator.ActionValidatorManager)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.util.ValueStackFactory)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.util.reflection.ReflectionProvider)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.util.reflection.ReflectionContextFactory)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.util.PatternMatcher)
INFO: Choosing bean (struts) for (org.apache.struts2.dispatcher.StaticContentLoader)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.UnknownHandlerManager)
INFO: Choosing bean (struts) for (org.apache.struts2.views.util.UrlHelper)
INFO: Choosing bean (struts) for (com.opensymphony.xwork2.util.TextParser)
Mar 12, 2015 8:01:59 AM org.apache.struts2.config.DefaultBeanSelectionProvider info
INFO: Loading global messages from [ApplicationResources]
Mar 12, 2015 8:01:59 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory /var/lib/tomcat7/webapps/ROOT
Mar 12, 2015 8:02:00 AM org.apache.coyote.AbstractProtocol start
INFO: Starting ProtocolHandler ["http-bio-8080"]
Mar 12, 2015 8:02:00 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 93559 ms
