Sberbank
RU
The Error while openning a node in System Management Application
Hello Everyone!
Pega PRPC version is 6.1 SP2
After adding a node in System Management Application there is an error on the web page instead of this node components:
Failed to get mbean server connection
SMA ERROR: Failed to create admin client
ADMC0016E: The system cannot create a SOAP connector to connect to host myhost.com at port 9080.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689977000/82e93177-3fd9-42a0-91c7-73697a6a3024.jpg?itok=8Yq6mR5q)
Could you please check whether the prmbeans.properties file is intact on your server and it is not tampered. Please take the help of your PRPC sysadmin to locate this file. I guess that the prmbeans.properties file is having some problem.
Sberbank
RU
SATAS,
file prmbeans.properties exists on the server:
ll prmbeans.properties
-rwxrwxrwx 1 wasadmin wasadmin 190 Jun 15 2009 prmbeans.properties
bash-3.2$
bash-3.2$
bash-3.2$ cat prmbeans.properties
#Default MBean security configuration.
deny.DatabaseManagement.DatabaseConnectionDetails = true
deny.RequestorManagement.RequestorDetails = true
deny.RequestorManagement.Clipboard = true
WellCare
Do you have the server in another box other than your deployment manager?
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2024-03/0ea0d77b-d43b-4a29-9ee1-3bdd2155a6ba.png?h=d74b095e&itok=kMbovT72)
Hi OlegC842,
This may be the result of some configuration problem that is not readily apparent and will require a more thorough review of your System Logs to properly troubleshoot. Please submit a Service Request (SR) so one of our technicians can work with you. You can do so by accessing the new My Support Portal (https://collaborate.pega.com/question/how-raise-sr-my-support-portal-how-question).
Henry
Pega Academy
Sberbank
RU
The problem is solved.
The port must be changed to SOAP port value/
WellCare
Great, yes usually the SOAP port in websphere is 8880 not 9080.
Cognizant
I have given the same port vaule, however its not working yet,
Caused by: java.lang.Exception: Fail to instantiate WASJMXConnector
ADMC0016E: The system cannot create a SOAP connector to connect to host hostname at port 8881
Please help
Thanks!
Services Australia
Try using port 8880
Vamshi
Cognizant
Dear Vamshi,
Thanks for your kind update, however issue was fixed.
I have already tried as you mentioned above but the issue was'nt fixed.
Finally found there was SSL handshake issue with the node and it has been fixed and then able to login into the console without any issues.
Thanks!
Riaz
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1690554000/931fffe1-484d-46d4-ae28-01ca8b2ad775.jpg?itok=3IdBMctp)
LLoyds Banking Group
HI Riaz-
Please can you let me know what exactly you have done to fix the SSl handshake issue?
We are also following the similar issue where in couple of nodes configured on the SMA are not getting connected.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689956000/f7ad973e-3d46-4a14-b745-1ca96a4e8384.jpg?itok=hmXcN_11)
Hi
I am facing the same issue.
May I know where do I specify the SOAP port value?
Thanks.
Rgds,
Gay
Cognizant
You have to login into the Pega consloe(http://localhost:9080/prsysmgmt)
Once loggedin, in the left side, click on the Jvmnode and edit, after clicking on edit, in the right window there is a options to give the port value as 8880.
Thanks!
Riaz
Thanks Riaz
