Report Defination - You are not authorized
 I have an operator 'ABC', and two environments 'Dev' and 'Test'. In Dev i'am able create a case and link fews to the case and check linked cases to the case, but where as in Test enviroment when i create a case and try to link cases to it, cases are not getting linked and no cases are getting displayed to the case.
 Below is the error go from the tracer.
Error:
FAIL
 Step Status Info   You are not authorized to open instance RULE-OBJ-REPORT-DEFINITION LINK-XXXXXX XXXX #201XXXXXT160733.348 GMT
Please share your inputs if you have any suggestions on this. Thanks.
