Accenture
Last activity: 7 Oct 2015 16:27 EDT
While Deploying prpc_j2ee14 Application getting error in PEGA 7.1 .7 Version
Team,
Please help me to find the solution of the issue in PEGA 7.1.7.
My configuration :
installed Pega 7.1.7 in Linux with oracle 11.2.0.4 Version Database and also installed Weblogic 11g(10.3.6.0), while deploying prpc_j2ee14.ear file we are getting some error. Please find the error pasted below.
ERROR:
####<May 22, 2015 2:01:53 PM IST> <Emergency> <com.pega.pegarules.internal.bootstrap.PRBootstrap> <TACOEPEGADEV.gdnindia.com> <AdminServer> <[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)'> <weblogic> <> <> <1432283513176> <BEA-000000> <prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings>
####<May 22, 2015 2:01:53 PM IST> <Error> <com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource> <TACOEPEGADEV.gdnindia.com> <AdminServer> <[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)'> <weblogic> <> <> <1432283513177> <BEA-000000> <Unable to obtain DataSource for java:comp/env/jdbc/PegaRULES; javax.naming.NameNotFoundException: While trying to look up comp/env/jdbc/PegaRULES in /app/webapp/prweb/1433747971.; remaining name 'comp/env/jdbc/PegaRULES'>
####<May 22, 2015 2:01:53 PM IST> <Emergency> <com.pega.pegarules.internal.bootstrap.PRBootstrap> <TACOEPEGADEV.gdnindia.com> <AdminServer> <[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)'> <weblogic> <> <> <1432283513178> <BEA-000000> <PRBootstrap.calculateEngineCodeVersionFromDB() - unable to calculate codeset version from database: null>
####<May 22, 2015 2:01:53 PM IST> <Emergency> <com.pega.pegarules.internal.bootstrap.PRMiniLoader> <TACOEPEGADEV.gdnindia.com> <AdminServer> <[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)'> <weblogic> <> <> <1432283513178> <BEA-000000> <Will load phase 2 bootstrap from Pega-EngineCode:>
####<May 22, 2015 2:01:53 PM IST> <Emergency> <com.pega.pegarules.internal.bootstrap.PRBootstrap> <TACOEPEGADEV.gdnindia.com> <AdminServer> <[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)'> <weblogic> <> <> <1432283513179> <BEA-000000> <
============ PegaRULES Bootstrap Configuration ============
Date: Fri May 22 14:01:53 IST 2015
Java Version: Oracle Corporation 1.7.0_79
Configuration: zip:/u01/app/Middleware/weblogic/user_projects/domains/pega_domain/servers/AdminServer/tmp/_WL_user/prpc_j2ee14/2zj6g8/APP-INF/lib/prresources.jar!/prbootstrap.properties
Pega-EngineCode:
(!) Unable to locate classes on filesystem
=============== End Bootstrap Configuration ===============
####<May 22, 2015 2:01:53 PM IST> <Error> <com.pega.pegarules.internal.bootstrap.PRBootstrap> <TACOEPEGADEV.gdnindia.com> <AdminServer> <[ACTIVE] ExecuteThread: '2' for queue: 'weblogic.kernel.Default (self-tuning)'> <weblogic> <> <> <1432283513180> <BEA-000000> <Error initializing PRAppLoader
java.lang.ClassNotFoundException: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
at com.pega.pegarules.internal.bootstrap.PRMiniLoader.loadClass(PRMiniLoader.java:388)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.loadPhase2BootstrapClass(PRBootstrap.java:685)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:629)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:376)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:216)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:265)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextDestroyed(WebAppLifeCycleListenerBoot.java:67)
at weblogic.servlet.internal.EventsManager$FireContextListenerAction.run(EventsManager.java:482)
at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120)
at weblogic.servlet.internal.EventsManager.notifyContextDestroyedEvent(EventsManager.java:200)
at weblogic.servlet.internal.WebAppServletContext.destroy(WebAppServletContext.java:3225)
at weblogic.servlet.internal.ServletContextManager.destroyContext(ServletContextManager.java:247)
at weblogic.servlet.internal.HttpServer.unloadWebApp(HttpServer.java:461)
at weblogic.servlet.internal.WebAppModule.destroyContexts(WebAppModule.java:1545)
at weblogic.servlet.internal.WebAppModule.deactivate(WebAppModule.java:509)
at weblogic.application.internal.flow.ModuleStateDriver$2.previous(ModuleStateDriver.java:387)
at weblogic.application.utils.StateMachineDriver.previousState(StateMachineDriver.java:223)
at weblogic.application.utils.StateMachineDriver.previousState(StateMachineDriver.java:215)
at weblogic.application.internal.flow.ModuleStateDriver.deactivate(ModuleStateDriver.java:141)
at weblogic.application.internal.flow.ScopedModuleDriver.deactivate(ScopedModuleDriver.java:206)
at weblogic.application.internal.flow.ModuleListenerInvoker.deactivate(ModuleListenerInvoker.java:261)
at weblogic.application.internal.flow.DeploymentCallbackFlow$2.previous(DeploymentCallbackFlow.java:547)
at weblogic.application.internal.flow.DeploymentCallbackFlow.deactivate(DeploymentCallbackFlow.java:192)
at weblogic.application.internal.flow.DeploymentCallbackFlow.deactivate(DeploymentCallbackFlow.java:184)
at weblogic.application.internal.BaseDeployment$2.previous(BaseDeployment.java:677)
at weblogic.application.utils.StateMachineDriver.nextState(StateMachineDriver.java:63)
at weblogic.application.internal.BaseDeployment.activate(BaseDeployment.java:212)
at weblogic.application.internal.EarDeployment.activate(EarDeployment.java:59)
at weblogic.application.internal.DeploymentStateChecker.activate(DeploymentStateChecker.java:161)
at weblogic.deploy.internal.targetserver.AppContainerInvoker.activate(AppContainerInvoker.java:79)
at weblogic.deploy.internal.targetserver.operations.AbstractOperation.activate(AbstractOperation.java:569)
at weblogic.deploy.internal.targetserver.operations.ActivateOperation.activateDeployment(ActivateOperation.java:150)
at weblogic.deploy.internal.targetserver.operations.ActivateOperation.doCommit(ActivateOperation.java:116)
at weblogic.deploy.internal.targetserver.operations.StartOperation.doCommit(StartOperation.java:149)
at weblogic.deploy.internal.targetserver.operations.AbstractOperation.commit(AbstractOperation.java:323)
at weblogic.deploy.internal.targetserver.DeploymentManager.handleDeploymentCommit(DeploymentManager.java:844)
at weblogic.deploy.internal.targetserver.DeploymentManager.activateDeploymentList(DeploymentManager.java:1253)
at weblogic.deploy.internal.targetserver.DeploymentManager.handleCommit(DeploymentManager.java:440)
at weblogic.deploy.internal.targetserver.DeploymentServiceDispatcher.commit(DeploymentServiceDispatcher.java:163)
at weblogic.deploy.service.internal.targetserver.DeploymentReceiverCallbackDeliverer.doCommitCallback(DeploymentReceiverCallbackDeliverer.java:195)
at weblogic.deploy.service.internal.targetserver.DeploymentReceiverCallbackDeliverer.access$100(DeploymentReceiverCallbackDeliverer.java:13)
at weblogic.deploy.service.internal.targetserver.DeploymentReceiverCallbackDeliverer$2.run(DeploymentReceiverCallbackDeliverer.java:68)
at weblogic.work.SelfTuningWorkManagerImpl$WorkAdapterImpl.run(SelfTuningWorkManagerImpl.java:545)
at weblogic.work.ExecuteThread.execute(ExecuteThread.java:256)
at weblogic.work.ExecuteThread.run(ExecuteThread.java:221)
Kannan
