Merkle Inc
ES
Last activity: 18 Apr 2016 9:55 EDT
VM Virtual box really slow
Good mirning, I asked before about that more or less. Currently I can connect de VM but, it really takes so time to connect, Maybe one or two hours. I dont understand because it occurs, but I cannot work easily with that. I spend a lot of time waiting the VM works.
Please, may you tell me some advice to improve that time? Ive already desinstall and install the VM Virtualbox. Download again the system exercise. But it cannot work faster. maybe even slower.
Hello Elena
Can you please share the specifications of your host machine: memory and CPU?
The exercise system virtual machine uses 4 GB and 2 CPUs from the host machine. If the host machine has only marginally higher memory and CPU than this (example 6 GB and 3 CPUs), then it is likely that you will see slow performance on both the virtual machine and the host machine.
You can reduce the memory and CPU allocated to the virtual machine and see if it helps. In the VirtualBox, right-click on the virtual machine and select Settings. Go to System where you will find both memory and CPU settings.
Regards
Guru
