JP Morgan
Upgrade from Pega 5.5 to 7.2 : upgrade.sh/resume.sh logs does not update after certain point
Dear Team,
We ran upgrade.sh and observed that logs stops updating after certain point, we killed the command and ran resume.sh but still the issue is same. The logs stop updating at the same point.
Last logs at which the logs stop updating (CLI-Resume-log-May-03-2016-11-25-11.log)
ad 5020 class definitions
[java] 2016-05-03 11:28:05,678 [ main] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Data-Rule-ClassAncestor class is not available, skipping table population
[java] 2016-05-03 11:28:05,704 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Loading pr4_base_07.10.01.zip
[java] 2016-05-03 11:28:05,728 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Operation Status: Bootstrapping Base Instances
[java] 2016-05-03 11:28:05,737 [ main] [ ] [ ] (pboard.StorageStreamCommonImpl) INFO - Storage stream version is 6
Contents of resume.properties
#Tue May 03 11:27:27 EDT 2016
completed.steps.RemoveInvalidSettings=true
resume.user.temp.dir=/apps/gcsa1/pega7.2/tmp
resume.action=upgrade
resume.current.version=05-05-16
upgrade.from.version=05-05-16
completed.steps.GenerateUpgradeDDL=true
resume.install.temp.dir=/apps/gcsa1/pega7.2/tmp/PegaInstallTemp-02-May-2016-23.12.45
completed.steps.UDFApplication=true
completed.steps.EngineLoad=true
resume.user.temp.dir.root=/apps/gcsa1/pega7.2/tmp
resume.rulesload.lastattemptedarchive.PegaRULES\ ProcessCommander\ V07=pr4_base_07.10.01.zip
No ORA errors found in logs
Please help me in troubleshooting this issue. Thanks
Venugopal Adep
