Upgrade.sh and Resume.sh Stopped at one point and not moving forward
We are trying to Upgrade.sh for Rule Upgrade from 5.5 to 7.1.9 Upgrade split schema approach. Upgrade.sh file stopped at below point, so we tried running resume.sh and again it stopped at below point . Everytime we try to run it stops as the same point and doesnt progress. Please adivse
Engine Load Inner:
[java] Aug 30, 2016 3:25:59 PM com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource
[java] 19830421: Loading bootstrap properties from file:////opt/waslogs/tempdirupgrade/PegaInstallTemp-30-August-2016-15.23.43/prbootstrap.properties
[java] Aug 30, 2016 3:25:59 PM com.pega.pegarules.internal.bootstrap.SettingReaderJNDI
[java] 19830421: Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
[java] 19830421: Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
[java] 19830421: Unable to locate archive.properties properties, setting warVersion to -1
[java] 19830421: Engine schema defined in allclasses: null
[java] 19830421: Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
[java] 19830421: Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
[java] 19830421: Engine classes schema: null
[java] 19830421: Assembled classes schema: null
