Unable to identify the flow diagram in Pega 7.2
The process diagram/ flow diagrams designing in SAE1 course not able to locate in Pega7,2
What are you trying to do? In SAE1 (which is based on 7.1.6) you create a new application and all the rules.
What cannot you find?
Damien
Hi Damien,
I am trying to use framework layer flows in implementation layer case type rule it shows the below message
Is there any document for using framework layer flows etc in implementation in 7.2
