WellCare
Last activity: 1 Dec 2016 7:16 EST
SAE 7.2 - Exercise: Configuring a decision table to route Facilities requests - Errors saving updated Facilities Setup Flow Diagram
After adding the "Approval" connector, and turning 'Draft off' I am given two errors -
Connector "Select Seating Location"
"Condition - Unable to open an instance using the given inputs: Rule-Obj-FlowAction TGB-HRApps-Work-Onboarding.SelectOfficeEquipment_0"
and connector "Select office Equipment"
"Condition - Unable to open an instance using the given inputs: Rule-Obj-FlowAction TGB-HRApps-Work-Onboarding.SelectSeatingLocation_0"
Screenshot attached.
Errors were not present prior to this exercise.
I tried testing the changes, but it does not behave as expected.
I am also experiencing the same error -- and when I try to complete the exercise, the Facilities Setup step routes to System Architect instead of the desired "workbasket".
