HCL
Last activity: 23 Oct 2015 8:19 EDT
Troubles in Control Group exercise using Segment rule HighValueBranch1
In the exercise for Control Group when I create the segment rule HighValueBranch1. I faced few difficulties
1) The filter conditions in this rule does not behave the same way as When rules or Report definition rules. For e.g: Add 3 filter criterias (A, B and C), however you only want to use A and B. You cannot do this, unless you delete C from the list of criterias.
2) To troubleshoot the issue, if you move away from the non Pictorial view to the Pictorial view, the conditions are not moved and vice versa.
3) The run button is only enabled after checkin the rule.
What is the reason's for above behaviors?
Thank you
Titto
