Storing a PRPC generated XML stream in Oracle XMLTYPE column
We have a requirement to consume an XDS, generate an XML out of it and storing it in an Oracle DB column of XMLTYPE. We tried using setting the stream to a scalar property using property-set-xml method, but that would not work since it is expecting to map the data to a VARCHAR column in the database. If any one has encountered similar situation, any help regarding the same would be highly appreciated.
