L&T Infotech
XML Stream rule to generate XML with using complex external xsd
We have a requirement to generate complex xml message using external xsd file. XSD file has elements which are extended from other elements. Also, we need to map specific elements using xpath as there are chances that xsd might have frequent changes.
We are using pega 5.5 version. I am looking for a approach to handle such mapping in Pega. Also is it good idea to implement such complex mapping to generate XML in Pega. All the forums and articles talks more about parse xml so looking for solution more around XML stream.
Rakesh
