Same namespace gets generated when a XML stream rule calls another xml stream rule within it
Suppose I create 2 xml stream rules, say A and B . Stream rule A calls stream rule B ( using apply rule as the mapping mode)
Stream rule A
<ns1:table xmlns:ns1="http://www.w3.org/TR/html4/">
<ns1:tr>
<ns1:td>Apples</ns1:td>
<ns1:td>Bananas</ns1:td>
</ns1:tr>
</ns1:table>
Stream rule B
Stream rule A
<ns1:tr>
</ns1:tr>
</ns1:table>
Stream rule B
<ns1:table xmlns:ns1="https://www.w3schools.com/furniture">
<ns1:name>African Coffee Table</ns1:name
<ns1:width>80</ns1:width>
<ns1:length>120</ns1:length>
</ns1:table>
And the final xml generated run will look like :
<ns1:tr>
</ns1:tr>
</ns1:table>
</ns1:table>
As you can see the namespace prefix generated is the same for both the XML's ie ns1 even though the actual namespaces are different. Is there any way to change the namespace prefix? I tried changing the namespace where I call the second xml stream but no use.
( In the same xml stream rule if I use different namespaces it works perfectly ie it generates different namespace prefixes)
