Optum Technology
Last activity: 16 Mar 2018 19:46 EDT
Step Name Changes do not Display on Form
In Pega 7.1.9, after changing the step name in the case designer, the old step name still displays on the form during execution. Is this expected behavior? A known issue?
Are there any work arounds ?
Thanks!
Are you using Express or the Designer Studio?
This has been fixed in 7.2 which will be released shortly.
If you require a work-around for 7.1.9, I can provide the underlying rule metadata that needs to be changed to support this.
