Steps to be done for DB change.
Hi
We are in Pega 7.1.5 under Oracle. Our DB is shared with all Pega applications across LOB. We are planning to get our own box. How should we go with that? We need to reinstall Pega with the new box or moving the tables with appropriate grants will do.
Arvind B
Exporting DB and importing in newly created DB on new box should be right process.
Export should export all your DB objects.
Then, in your config, you need to update these DB setttings.
