RuleNotFound Pega-Landing-System-Upgrade during upgrade to 7.1.8
I am getting similar error listed below while doing the upgrdae from 55sp1 to 718 and attempted solution provided but still i am getting same error.
successfully started. TimeZone: US/Central AESPerfStatMode: PUSH Server: ftwlmscimw87 System: pega Description: ftwlmscimw87 pega 2016-02-24 16:08:40.936 GMT URL: [unable to determine]
[java] 2016-02-25 08:20:45,387 [ ftwlmscimw87] [ STANDARD] [ ] ( internal.mgmt.EngineImpl) INFO - Embedded Environment initialization is complete.
[java] 2016-02-25 08:20:45,407 [ ftwlmscimw87] [ STANDARD] [ ] (ernal.util.UpgradeRuleMessages) INFO - Upgrading Rule-Message instances...
[java] 2016-02-25 08:20:45,489 [ ftwlmscimw87] [ STANDARD] [ ] (l.access.RuleCandidateIterator) INFO - Single candidate rule resolution optimization is enabled
[java] Feb 25, 2016 8:20:46 AM com.pega.pegarules.internal.bootstrap.PRBootstrap
[java] SEVERE: Problem during method invocation (main)
[java] com.pega.pegarules.pub.generator.RuleNotFoundException: pyVTable-RuleNotFound-NoMatches RULE-OBJ-ACTIVITY PZUPGRADERULEMESSAGES Pega-Landing-System-Upgrade 2 The 2 rules named 'PZUPGRADERULEMESSAGES' defined in the rulebase are:
[java] 2 related to applies-to class 'Pega-Landing-System-Upgrade', but were defined in rulesets which are not in your rulesetlist: {Pega-LP-SystemSettings:07-10-15, Pega-LP-SystemSettings:07-10-17}.
[java]
[java]
[java] Current RulesetList:
[java] Pega-ProCom:05-05,
[java] Pega-IntSvcs:05-05,
[java] Pega-WB:05-05,
[java] Pega-RULES:05-05
[java]
[java] at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolver.throwDetailedRuleNotFoundException(VirtualTableResolver.java:726)
[java] at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolver.resolveToContainer(VirtualTableResolver.java:401)
[java] at com.pega.pegarules.generation.internal.vtable.ruleres.VirtualTableResolver.resolveRule(VirtualTableResolver.java:155)
[java] at com.pega.pegarules.generation.internal.vtable.VirtualTableImpl.resolveRule(VirtualTableImpl.java:301)
[java] at com.pega.pegarules.generation.internal.PRGenProviderImpl.get(PRGenProviderImpl.java:474)
[java] at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3483)
[java] at com.pega.pegarules.deploy.internal.util.UpgradeRuleMessages.main(UpgradeRuleMessages.java:79)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
[java] at java.lang.reflect.Method.invoke(Method.java:597)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
[java] at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
[java] at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85)
[java] Feb 25, 2016 8:20:46 AM com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega
[java]
[java]
[java]
[java] Exception in thread "ftwlmscimw87" java.lang.RuntimeException: Problem during method invocation (main)
[java] at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:278)
[java] Caused by: com.pega.pegarules.pub.generator.RuleNotFoundException: pyVTable-RuleNotFound-NoMatches RULE-OBJ-ACTIVITY PZUPGRADERULEMESSAGES Pega-Landing-System-Upgrade 2 The 2 rules named 'PZUPGRADERULEMESSAGES' defined in the rulebase are:
[java]
[java]
[java]
[java] ... 1 more
Please provide a solution if it is known issue.We never faced this issue in lower regions and happening only on model.
https://pdn.pega.com/support-articles/rulenotfound-pega-landing-system-upgrade-during-upgrade-717
