BlueRose Technologies
Posted: Jun 4, 2016
Last activity: Oct 4, 2018
Query on LSA (7.1) Quiz - Design Pattern: Dynamic Class Referencing
Which of the following describes a typical use case for the Dynamic Class Referencing pattern? (Choose One)
1. To route work to a workbasket that is given by the operator’s work group
2. To initiate implementation layer work types from the framework (Correct Answer)
3. To reuse flow from the framework in the implementation layer
4. To make a flow in the framework layer more reusable
W.r.t. the above quiz question, we have seen in the course that a dynamic behavior in the flow rule like routing to WB where the WB name can be sent as a parameter to the flow rule. Then, why are options 3 and 4 incorrect?
